Results 1 to 6 of 6
Thread: Fuel Leak
    Jan 2005
    Los Angeles
    635 CSI
    Fuel Leak
    Hi All,
    I have an '86 635csi that has been sitting in my driveway for a while. When I started it, fuel started leaking from a hose somewhere towards the firewall on the left side of the engine bay. For some reason I just cannot locate the leak! Does someone have a fuel like diagram for this car so I can locate what fuel lines are where?
    Much appreciated!
    Dan
    North Carolina
    '86 M635/'10 Clubman
    Quote Originally Posted by shotstew View Post
    Hi All,
    Much appreciated!
    Dan
    The fuel lines run up the passenger side, and a rubber line comes up to the fuel rail (at least on my M635). That was the source of my recent leak.
    It's probably worth going through and replacing all of the fuel lines. I missed the one I mentioned when I did it the first time. I also just did the lines from the in-tank pump down to the main fuel pump and filter. That's a bit of a PITA, but still worth it.
    Sep 2010
    Hagerstown,MD
    1984 Euro 635
    The hard (metal) fuel lines end on the drivers side firewall. Hard to see cause they are down under the brake bomb tucked back in the corner. From there the rubber hoses run up to the fuel rail and pressure regulator. If you locate the junction and replace the hoses don't forget the hose from the center of the fuel rail to the cold start valve.
    '84 Euro 635
    '88 M6 (Gone but not forgotten)
    Boston, Ma
    86 635,72 E3, 88M6,73 E9
    George, my thought exactly...the hose to the CS valve................the worst one to deal with IMO
    Rob E3
    Sep 2010
    Hagerstown,MD
    1984 Euro 635
    Quote Originally Posted by RSheiman View Post
    Rob,
    I recall the first time I replaced that bugger. Wasa told could not be done without removing the intake. I did it without but sure as hell can't begin to explain how...
    '84 Euro 635
    West Nyack, New York
    86 635csi 98 740i 96 MB
    Let me chime in hear, it is one of the worst fixes a real PITA.
    Since I was replacing with a new one, I chiseled the old one off to gain
    easier access to the bolts. Then I used allens to bolt that sucker back on.
    The curved allen key made it fairly easy to tighten up the allen bolts.
    I'm with George, no way I'm taking that intake off.
  1. Fuel leaking
    By azatty in forum 1991 - 1999 (E36)
    Last Post: 03-17-2004, 11:11 AM
  2. Motor died and will not restart - fuel leaking from rail/injectors
    By Mad Dog 20/20 in forum 1992 - 1999 M3 (E36)
    Last Post: 01-30-2004, 05:48 PM
  3. 1992 325i fuel leak
    By Patrick Bateman in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 08-06-2003, 09:33 AM
  4. Fuel Leak
    By 318ispower in forum 1991 - 1999 (E36)
    Last Post: 11-20-2002, 02:49 AM
  5. E36 fuel leak revisited
    By ToneCapone in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 06-17-2002, 07:37 PM
