I have a 1989 535i e34 with the m30 engine it runs great with 220,000 miles but the idle is very very rough I got a zip tie on the throttle cable making it idle 200 rpms higher then it should which helps a lot but it is still KNOCKING pretty loud at idle but goes away as soon as it gets over 1500 rpms please help
Knocking or tapping? Any video? Knocking spells disaster, RPM change is interesting.
O o
/Ż____________________________ ______________
| BLAAAAAAAAAAAAAAAAAAAHHHHHHHH! !!!!
\_ŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻ ŻŻŻŻŻŻŻŻŻŻŻŻŻŻ
I would be looking at replacement engines, if I were you. I had the exact same situation, starting knocking right after a valve adjustment, I wrote it off as potentially something else other than impending doom. Engine seized up on a freeway onramp, and later inspection revealed an oilpan full of fine metal fragments. Bearings gave up the ghost. 450 bucks later, and a few headaches, she's running better than new. Maybe someone will chime in saying it's piston slap or something else that might be liveable, but I would be looking at your options. A deep knocking can only really be a few things.
