Results 1 to 4 of 4
Thread: 1988 BMW 750il DIY
    Nov 2017
    florida
    1988 bmw 750il
    1988 BMW 750il DIY
    Hello, bought my old grandpa 3 years ago, from that day practically i rebuild the whole car with shoguns and sean and other guys info and tips. I am professional upholstery guy from Sarasota FL so i have patient and patient to do tidious job i was in those car since i was 10 years old i knew all wrenching basics worked on my offroad bikes where everything needs to be perfect that engine work perfectly so i had basic for all the jobs, Big thank you guys who wrote all diy fixes and tips BIG BIG THANK YOU.
    Ok about e32 m70:
    1. Engine bay valve cover gaskets.
    If you guys see leak on valve covers I encourage you to replace them, job is not hard just tidies, for intake manifold i didn't used swivel (mine extensions were beat up so it worked as a swivel) i just used two long extension 1/4 and short not deep 10 mm socket, while you there i would replace like that battery cable, ofc Banjo bolts !!!! Mine were holding on maybe two threads. Also I replaced all fuel hoses, water pump, ofc spark plugs, alternator ( wiggled it out through top without taking radiator, you have to play with it its like those puzzles at one point it comes out), both belts and tensioners (they are weird i load them and they squirted oil on me i though that i broke it but it seems everything ok), without intake manifold it is piece of cake to work on m70. Good luck.
    2. Ok ok mine upper oil pan gasket well I ignored it, to the point where started to see that gaske by it self are slipping out, then i said ok its time.
    Well this is the most difficult job because i am tall and the lift is not that tall, I REALLY RESPECT THOSE GUYS WHO WORKS IN SMALL GARAGES WITH A PIT OR ON THE CREEPER BIG RESPECT, procedure is straight forward support engine from the top, on the bottom i just lower subframe supported it I didnÂ’t disconnect no power steering hose, i know i know but no harm no fault, and upper oil pan goes put easy, be patient all car is like thos puzzles: do slow, grow 2 more pairs of arms and get 1 pair of extra eyes, but it comes out and goes in easy. But the problem that your back hurts and arms always up and eyes... Dont be afraid to drill holes in the cover, i used wide STEP bit go slow be patient AND DRILL HOLE KINDA CLOSE BY THOSE LOWER BOLTS I MEAN MORE TO THE BOTTOM AS POSSIBLE THAT GIVES YOU VERY EASY ACCESS TO THE BOLTS, with swivel and 1/4 extension, use flash light and you actually can see those bolts through the belhousing hole.
    3. Driveline
    I had a a kick from 1 st gear to second and felt little vibration in the middle, and weird SUSPN LEVELING warning, but cars height was ok it does not drop or something, so i replaced CSB AND I FOUND THAT MY HEIGHT ADJUSTMENT BOX IS HANGING ON THE ROD AND BOTTOM FELL OUT OF ITS PLACE so i put washers and longer nut now car is in perfect height and driveline is in good line so it cured problems like shifting from 1to second the kick is more like not notisible and vibration is gone. You can slide CSB with the same bolt, dont forget to preload CSB it means install drive shaft both sides then install csb bolts and push CSB bracket forward to the tranny about 4 mm and then tighten CSB bolts thats it.
    Car runs good like never before, shifts good, oil leak free I am very happy. Hopefully this info will rise your morale to do the job by your self, just gather as much info as you can before you go do something on your beemmer.
    Last edited by vinaslinis; 05-22-2019 at 10:29 AM. Reason: I Am lithuanian English is not very good
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    no worries, we understand, our group of E32 enthusiasts comes probably from all continents and many countries.
    NYC & Long Island & So FL
    '93 740il '84 633Csi
    Hey Vinaslinis,
    Are you actively doing auto upholstery work in Sarasota or are you retired? I may be looking for some custom work in the next year or two.
    --Ken
    Nov 2017
    florida
    1988 bmw 750il
    Yes I am from Sarasota, I am master upholster I work coorporated with Mike’s auto trim located on 1900 N Washington blv, Sarasota FL 34237, Look for Ed tall guy thats me, I do boats, cars, headliners, (did my e32 in black suede plus pillars, looks great) furniture, will throw some pictures of my work later, I do custom jobs too, customer or me can make layout of you wanted interior and i can make it, i can customize your seat foam and make custom covers, i do convertible tops, and everything what goes bad with those, like cylinders, pumps, lines, and etc.
    Here some pics of my work:
    https://ibb.co/C5mj7VM
    https://ibb.co/RNC15yR
    https://ibb.co/4gqj7LC
    https://ibb.co/FWRqHfB
    https://ibb.co/jT58wNh
    https://ibb.co/K5bgzZf
    https://ibb.co/qrshhH9
    https://ibb.co/pvydLC5
    https://ibb.co/LtzT04X
    https://ibb.co/k5MYZZX
    https://ibb.co/r34qf5j
    https://ibb.co/XZGcMf8
    https://ibb.co/TrzG7dM
    https://ibb.co/JxXCntP
    https://ibb.co/0DQMNJK
    https://ibb.co/VpbGMhs
    https://ibb.co/nPdK7nn
    https://ibb.co/3kssFNb
    https://ibb.co/sVRYgz7
    https://ibb.co/T1pRq51
    https://ibb.co/89zZz4Z
    https://ibb.co/X3jWMW1
    https://ibb.co/9vYfV7Q
    https://ibb.co/8MhqDdj
    https://ibb.co/nfvtZ3H
    https://ibb.co/YfX8Nvp
  1. 1988 BMW 750il power brake booster rebuild kit
    By THE DONALD in forum 1988 - 1994 (E32)
    Last Post: 04-13-2009, 10:09 PM
  2. 1988 BMW 750iL
    By arnzng in forum 7 series
    Last Post: 04-15-2008, 08:19 PM
  3. 1988 bmw 750iL for quick sale!
    By deprato07 in forum BMW Cars For Sale / Wanted
    Last Post: 07-18-2007, 08:24 PM
  4. 1988 BMW 750il Dinan Twin Turbo
    By djkustomz in forum BMW Cars For Sale / Wanted
    Last Post: 06-18-2007, 07:09 PM
  5. 1988 BMW 750IL So-Cal:
    By campbelljd in forum BMW Cars For Sale / Wanted
    Last Post: 03-25-2003, 11:25 AM
