Results 1 to 23 of 23
Thread: Changing the headliner to black (rant)
    Dec 2002
    Toronto Canada
    2000 750iL
    So I'm taking on the wonderful task of changing over the lite grey headliner to black. It had started to sag in the back. So what the heck. How hard can this be eh.
    So this will include recovering the A/B/C pillars as well as a color change to the "oh-shite-handles", the various other lights and ceiling stuff and the sun visors. The dismantling to get it all out was fairly smooth with the help of various posts here and some videos. With all the parts out was time to strip the old dirty grey saggy material off.
    But oh my GAWD !!
    Whoever was the D-bag that thought this orange foam and glue from Satan himself was a good idea should be punctured by one thousand hornet stings and forced to listen to ABBA for the remainder of their pitiful life. What a mess. Don't be fooled by how easy that cloth headliner first pulls off. What comes after that's UNDER that cloth is hours of blissful galactic mess that just gets into everything and goes everywhere. It's an absolute SHYTFEST !!! And don't let this picture fool you into thinking "oh..... that doesn't look too bad at all...... what could he be talking about ......"
    Anyways, I'm pushing forward. There has been a few stumbles along the way as I'm an older guy and my skills are not exactly what they use to be. Mind you I set my standards pretty high as well. Regardless, it will get done. The A/B/C pillars are wrapped and all done, center and front ceiling consoles have been wrapped, and visor light trims painted. I'm trying to see if I can source out some black sun visors from another car somehow as well as the "oh-shite-handles". So far no luck yet. And the BIG task of laying down the black microsuede on the main ceiling card has still be done. The only part of that job that has me nervous is the portion around the "oh-shite-handles" where I need to get the material to stretch into those pockets. That should be interesting. On that day, I think I will be cursing and sweating a lot.
    Anyways, stay tuned !!
    Tom
    Garage - 2000 750iL -- 2007 Z4M -- 2012 35d X5 mod'ed -- E30 M3 red valve cover -- tools -- misc BMW junk
    Lincoln Park, NJ
    2018 M3 6MT, 2001 740iL
    Lol. We are with you brother. Indeed that orange nonsense is pure evil. I had best luck with a putty knife to scrape the bulk of it off and a lot of latex gloves, a lot of paper towels, and cursing. When I did mine, I kept it stock-white-greyish to not need to worry about changing all you are doing. But in hindsight I somewhat wish I did go black.
    The indentations for the oh-shite handles were not so rough to stretch into ( assuming the cloth you have stretches ok ) The thing I had the problems with was cutting/tucking around for the sunroof. I botched this up a bit. when I was cutting the "pie cuts" to fold the cloth around the corners and stretch it in, I did not leave enough material on the innermost corners. As it folded over it stretched out, and left a little bit of uncovered 2-5mm section with the edge of the cloth visible on 2 corners. It didnt/doesn't bother me enough to re-do the entire thing. So there it stays. Good luck!
    Dec 2002
    Toronto Canada
    2000 750iL
    Yeah, this microsuede I have doesn't stretch all that great due to the backing. But I will figure it out. My issue at the sunroof was that the rounded corners on the card didn't fair perfectly when stripping the glue off. So I've put down an fine coating of body filler and going to smooth those rounded corners back to perfection.
    I used two putty knives to get that orange foam and "guck" off. One to scrape one to clean the scraper !! I then went back over the entire card with a glue remover to try and clean the card up properly. I wanted that card to be fairly clean and smooth so that there were no imperfections showing through the covering if you rubbed your hand across it. Painful and it wasn't close to perfect either. And oh yes, latex gloves for sure. A lot were used. Another note is this. I would strongly recommend getting the foam and Satan glue off the backside as well. When you are recovering the cards and are handling them, if there is crap on the backside and you get that on your hands, you can be fairly certain you will be getting that shite on the good side just due to handling. So be mindful of this.
    A few other notes. I set up a good size table on two saw horses that allowed me to walk around the entire headliner card. If you are doing this job, give yourself lots of space. And do it somewhere that is not a problem to get shite everywhere. DO NOT DO THIS IN YOUR KITCHEN!! The glue scrapings ended up on my garage floor and it makes a sticky mess everywhere. And I was pretty diligent about trying to keep clean and tidy. And then once you are done cleaning off all the cards and such, put it all aside and CLEAN UP EVERYTHING thoroughly. You do NOT want to get that Satan spawn guck stuff on your new coverings.
    Just of note, when I was taking out the headliner, my car had no seats or carpets in the car. I'm changing my seat bases to black and also installing black carpet. Anyways, having all that stuff out seems to make pulling the headliner out very easy. I can't comment on the effort if the seats are still in the car.
    ALSO......... thoughts on replacement "oh-shite-handles" and sunvisors? I've heard black ones from the same generation of 5-series and X5 can work? Can anyone confirm this at all ??? Or has anyone had any real long term success with dying or painting these parts ? Thanks in advance.
    Tom
    Dec 2009
    Dallas,TX
    '98 E38 740IL, '01 740i
    Quote Originally Posted by tominizer View Post
    Just wanted to pop in here and say I'm doing this same job and yeah it does suck.
    And as for the handles, e66 handles will work also, and for the visors e53 X5 ones will work and if you want to get fancy e39 m5 leather visors will bolt up as well.
    Sent from my SM-N950U using Tapatalk
    TRPCHGE - '01 740i Black/Black 230k'ish - Power folding mirrors, Mk.IV Nav, 16:9, M-pars, Sport seats, Sport wheel, Steptronic, Euro rear fog switch, 2.50" X-Pipe, Shadowline, E53 4.6is Cluster, Lacewood interior, Chromeline, 3.15, Bilstein B6+H&R Stage II's. - SOLD 06/21
    BSKCASE - '98 740il Arctic Silver/Black 175k'ish - Face-lifted, 3" Projectors, Shadowline, 01 Tails, Hydro Trunk, Sunshades, 750il Full interior retrofit, Sport Seats, Steptronic, Face-lift Steering Column, X5 Steering wheel, E53 4.6is Cluster, Euro E66 Piano black/Chrome Grab-handles, Chromeline, Suede Pillars/Headliner, Auto wipers/Lights, Lighted Handles interior/Exterior, Dual battery retrofit.
    WIP: Custom Style 42 18x9.5" ET12, 18x10.5" ET8, 3.15 LSD Rear diff.
    Dec 2008
    Washington, NC
    01 330 CiC, 05 X3 3.0
    Sadly, the orange stuff problem is endemic to all headliners, not just BMW. It's a mixture of foam and glue, and is the reason you can't just put the old headliner up with new glue - it needs the foam to make a good bond.
    I used microsuede when I redid mine, and looking back I wish I had used regular material.
    Oct 2013
    Louisa, VA
    2007 Z4 M Coupe
    I simply painted my "oh shite" handles black and they look great! Besides, no one grabs them, at least in my car...
    I also painted the sun visors, but recommend replacing them with OE ones (like e53, etc.)
    Current: 2007 Z4 M Coupe (blue/black)
    Previous: 2001 740iL Sport (black/black), 2000 528i Sport (black/tan), 1995 318is (black/black), 1991 318is (white/black)
    Oct 2008
    Madison, AL
    Check the Signature
    Well, maybe its a little late, but using some goo off and or brake parts cleaner and letting it soak and get clumpy makes it a LOT easier.
    I have done this a good few times. But even I am not masochistic enough to do this on the E38.
    Haha, have fun!
    Present:
    '96 750iL (Project)
    '95 C1500 350 V8
    '03 540i M Sport AT
    '22 GMC Sierra 1500 DD
    '92 Olds Toronado Trofeo (Project)
    Past:
    '93 325is (Parted)
    '95 840Ci (Sold)
    '86 735i (Parted)
    '02 Z3 3.0i (Sold)
    '09 328i (Leased)
    '91 750iL (Parted)
    '00 Z3 2.5i (Sold)
    '86 944 NA AT (Sold)
    '84 633 CSi (Sold)
    '06 X3 3.0 (Sold)
    '20 M2:Competition 6spd (Sold)
    Dec 2009
    Dallas,TX
    Quote Originally Posted by samsonevickis View Post
    Haha, have fun!
    So brake parts cleaner won't mess up the backing? I've done my pillars but I'm a bit hesitant to do the headliner
    Oct 2008
    Madison, AL
    Check the Signature
    Quote Originally Posted by Sabreslight View Post
    I had to do my A Pillars a few years back, didn't have a whole lot of time.
    I carefully pulled off the fabric, too reuse.
    Then misted the panels with brake parts cleaner and scraped away what I could with a plastic scraper. I didnt soak them. But no damage was done. As long as you don't soak the fiberboard stuff it should be just fine.
    Then I used a few clean terry towels with isopropyl 90% and got the rest of it off. I got lucky and the fabric wasn't badly contaiminated with the orange fuzz. So I was able to brush it clean and then used some kind of 3M fabric glue, not a spray. They are holding up just fine 18mo later.
    Present:
    '96 750iL (Project)
    '95 C1500 350 V8
    '03 540i M Sport AT
    Past:
    '93 325is (Parted)
    '95 840Ci (Sold)
    '86 735i (Parted)
    '02 Z3 3.0i (Sold)
    '09 328i (Leased)
    '91 750iL (Parted)
    '00 Z3 2.5i (Sold)
    '84 633 CSi (Sold)
    '06 X3 3.0 (Sold)
    Aug 2016
    Holland, Mi
    2000 740il, 1965 Mustang
    Maybe it's possible to use a portable sand blaster. Low PSI?
    Dec 2002
    Toronto Canada
    2000 750iL
    Yeah, that's another good point. Some of the Goo-off stuff stayed on my roof card a bit too long and softened the card. when I went across with the spatula things got torn up a bit and I had to repair those places. We'll see shortly how it all shall turn out. Hoping to cover the roof card this weekend.
    Tom
    Feb 2013
    The Motor City
    1997 750 IL
    You guys are doing it wrong!
    My black headliner and pillars are very nice and holding fine and I did not remove any of that dry foam. It's just a dry spongy material that already has a solid bond like you complain about right? So I just sprayed high quality liner glue right on it. The stuff soaks deep into the nice old crud and turns it back into a solid bond.
    ---- Processing Individual ----
    Z1XX Upholstery
    Seats front and back in Epingle / leather englishgruen,
    As Schl.Nr. B9EG.
    Front seat backrest in Montana Englishgruen (No. 8 174 861)
    Other interior equipment as for Volleder Nappa englischgruen,
    Schl.Nr. P5EG
    Dec 2002
    Toronto Canada
    2000 750iL
    So, headliner has been completed. I'm not entirely happy. For me to be entirely happy it has to look OEM new. It doesn't. But it was my mistake. The replacement fabric I used was micro suede. It has a backing on it that is NOT very stretchable. It actually has little to no give. Getting the grab handles done properly is a mission impossible given that fact. It does not conform into those grab handle pockets at all. I did the best I could to get it done. I may at some point re-do this headliner card, but next time it will be with another type of black material that I've used in the past with no backing. And it's not any type of suede.
    Anyways, A/B/C pillars all done as well. It looks really good if you don't know where to look (!!) and get your nose right up into it. It was a big job..... a dirty job. I also sourced out some black e53 X5 sun visors and they bolted up perfectly. Black grab handles from a newer 7-series (E66) on their way as well off Ebay. So that roof thingy almost all done. BTW, I looked for those E39 M5 leather sun visors. LOL, ouchy on the price !!
    I will try to post up some pictures shortly.......
    Tom
    Dec 2002
    Toronto Canada
    2000 750iL
    Here she is.
    Tom
    Rutland, Vermont
    E30 E38 E46 E85 F150 GTI
    Looks good.
    2000 740i Sport | 2004 330xi | 1988 325i Vert | 2003 Z4 2.5 | 1995 Ford F150 | 2018 GTI
    Dec 2009
    Dallas,TX
    Looks fantastic
    Dec 2002
    Toronto Canada
    2000 750iL
    What's interesting is once you have the black headliner card installed with black A/B/C pillars, man does it change the "feel" of the interior of the car. It's so much more intimate inside but in an evil way. I REALLY like how it turned out. Just waiting on the grab handles and to see how I can hopefully get those installed without damaging the headliner work.
    On another note, I changed the carpets to black as well from another 750il. The new (to my car) black carpet did not have the foot well lights on the back side behind your heels like my original TOBACCOBRUN carpet did. That was a surprise.
    Tom
    Lincoln Park, NJ
    I had the deck lid out for a suspension refresh a few weeks back, and speaker replacement.. and "while I was in there" put fresh black cloth on the speaker cover and the farther back piece with the sunshade bits. Anywhoo, I had better luck using a razor blade to scrape the goo off. Its all finally back together. I goofed on one cut though. I am a little short on material on the lower edge where the sun shade comes out. When its retracted, the sunshade covers it so its not a big deal. I got some rubber weatherstripping stuff to try and patch over it with. We shall see how that goes. Got some light grey of the same stuff on the way to patch up the good in the headliner in the sunroof opening I mentioned earlier.
    Indiana
    2001 740i M sport Imola
    Yikes, I never went through that nonsense. I pulled the headliner and pillars myself and handed them over to the accessory shop. Glad I did! LOL
    Dec 2002
    Toronto Canada
    2000 750iL
    Well, even though I used expensive glue ..... the RIGHT glue for headliners........ the sunroof pull shade piece with the cup handle seems to have fallen. So I have to pull that out and refinish it. Shitty. Fortunately, the rest of the headliner seems to be holding out decently. I don't know why, but when I was looking at it again, the idea of putting up some real deep shag on the roof liner crossed my mind. Kinda like a ghetto Cheech &Chong Weed filled Caddy theme thing........ I must have been way over-tired.
    Tom
    NYC
    99 IL/13 SXT/04 Audi A4
    HERE is mine
    New look
    El Cid 1999 IL
    DUDMD Tune/DINAN CAI/19 in Style 95 Rims/Bilstein's Shocks/Eibach Lowering Springs/OEM Folding Mirrors/Custom Cupholder/Custom Wood Sunshade/Sport Steering Wheel/Euro Center Console/Leather Shifter/Rearview Camera /Luke Custom 10 in Sub Box/Cross Drilled Rotors/Rear view Camera/BMW OEM Monitors/BMW E38 Picnic Tables/Vanity Headrests/OEM Roof Rack/Strut Bar/Dinan MAF and Dinan Throttle Body and Dinan tunning /BM53 Radio upgrade /Custom Innovadrive NXG39 modify and Alpine ILX-W650 touch screen radio.
    Dec 2009
    Dallas,TX
    Quote Originally Posted by franco90 View Post
    HERE is mine
    New look
    Looks fantastic
    Sent from my SM-N975U using Tapatalk
    Sep 2019
    Portland
    Too many to list
    I have a couple extra sets of sunvisors and grab handles in black if anybody needs em. Pm me
    Sent from my LM-G710 using Tapatalk
  1. Bad idea to change tan seats to black in a tan interior?
    By HID_Positive in forum BMW Rides & Events
    Last Post: 11-06-2006, 06:46 PM
  2. changed the headliner material
    By shogun in forum 8 Series (E31)
    Last Post: 10-15-2006, 10:15 AM
  3. Request... change dove seats to black *EASY
    By 96 328ic in forum BMW Rides & Events
    Last Post: 10-07-2006, 08:47 PM
  4. WTB: e36 sedan headliner, prefer black
    By m3kindaguy in forum BMW Parts Wanted
    Last Post: 06-10-2005, 04:54 PM
  5. Replies: 3
    Last Post: 08-04-2004, 07:18 PM
