Results 1 to 4 of 4
Thread: Need part # for this o-ring
    West Nyack, New York
    86 635csi 98 740i 96 MB
    Need part # for this o-ring_SOLVED_Press-Fit
    Didn't get # 9 in the OEM gasket set, looks like it would fit.
    #8 in the package does not fit, diameter too large.
    Did a general Google search for "dipstick tube 0 ring" and
    found rings but not for the m30 b34 block.
    There's no o ring groove on the bottom of my tube.
    As a matter of fact, no m30 was listed.
    If I can't get a part # can a guru tell me the o ring size.
    Or, do you think one of the listed rings would work for the m30--
    Or, if I measure the ID of the block and OD from
    the tube how thick of a generic o ring should I try to get.
    Posting on BigCoupe also.
    Thanks for all & any info.
    https://www.realoem.com/bmw/enUS/sho...diagId=11_3054
    Sep 2016
    North Florida
    1983 633csi, 2017 540i
    Aug 2011
    Ireland
    M3
    Hi
    If you look at that diagram the numbers are "greyed out" that generally means they are not for your car. I entered my vin and got the same diagram with the numbers "greyed out". This happens when there are different options and some diagrams say "no parts listed for your car"
    Does your car have an o-ring? A lot of the M30 dipsticks are an interference fit in the block with no o-ring used. If it needs one measure the outside diameter of the tube and the inside of the hole and see what thickness is available.
    Thanks for all the input.
    Talked to the builder and told me press fit.
    Old geezers always jump the gun.
  1. automatic----->manual tranny conversion...need parts!
    By KLEEN KUT in forum BMW Parts For Sale
    Last Post: 02-03-2002, 09:07 AM
  2. Any UK X5 drivers here? Need parts help.
    By roadsleeper in forum 1999+ X5, X6 (E53, E70, E71, F15, F16, G05, G06)
    Last Post: 01-14-2002, 02:17 PM
  3. Where to get 320i tranny mount? Need part#!!!
    By DINAN COSMOS in forum 1992 - 1999 M3 (E36)
    Last Post: 10-10-2001, 05:54 AM
  4. Need part numbers
    By jayhudson in forum 1992 - 1999 M3 (E36)
    Last Post: 09-06-2001, 09:32 AM
  5. Replies: 3
    Last Post: 07-16-2001, 03:28 AM
