Results 1 to 13 of 13
Thread: Strut spring compressor ?
    Feb 2015
    Uniontown, PA
    1999 Z3 roadster
    Im in the process of trying to remove the coil springs from my very spent front struts, got all new replacement parts, along with a new McPherson interchangeable fork style compressor tool kit, I tried to compress the coil, but of course the coil wont squeeze down enough to take the pressure off the upper spring bracket, so the next step would be between the upper bracket, and top hat if you will, but since the upper bracket is smaller than the lower spring mount, the top fork kind of looks like it could pop off, cause the inner lip cant get a good bite on the bracket, just curious if anybody else has had an issue with this?
    May 2015
    Springfield Il
    '97 Z3
    I had the same issue. My shops wall mounted spring compressor would not collapse the spring enough. While I would not recommend this, I ended up using ratchet straps to compress the spring completely. How the coils are spaced, a two part adjuster would most likely work the best. I don't know if I would trust these from Harbor Freight but something like this. https://www.harborfreight.com/automotive/auto-maintenance-repair/macpherson-strut-spring-compressor-set-63262.html
    San Diego CA
    2001 Z3 2.5i
    That is what I used, but the older version without the safety pins! Squint your eyes, turn your body away and have your wife dial 9-1- into her cellphone.
    Finished the job without any injury or damage, but my blood pressure was 5 points higher when I was done
    Feb 2015
    Uniontown, PA
    1999 Z3 roadster
    Quote Originally Posted by nthor71783 View Post
    Thanks for the response, but yeah man, I was checking those out, but decided to plunge for the more heavy duty deal, it does fit pretty good on top of the upper bracket, kind of gave it a test, got about 3/4 ay in, but began to get a bit skittish, and backed off lol, figured id take a stab at seeing how anybody else delt with this issue, besides, id look kinda funny driving my roady without my face howbowdit.
    Sep 2003
    kansas city
    98 Z3, 01 330i, 07 328iT
    I recently did mine using a compressor like this
    https://www.amazon.com/Shankly-Coil-...=strut&sr=8-16
    It was a bit awkward and unbalanced but it got the job done just barely.
    Fort Worth, TX
    E36M3/E46M3/E39M5/E63M6
    Honestly, I undid these struts with airgun without any compressor many times. They do pop off with force, but not enough to even jump off the strut stock most of the time. They kinda just violently disassemble themselves.
    E36/8 2000 M Coupe Cosmos Black/Black
    Shark, Conforti CAI, B&B Exhaust, H&R, Bilstein, AKG Subframe/Diff, UUC TME Red/Caps, Swapped Front Hats, Ice>Link.
    Feb 2015
    Uniontown, PA
    1999 Z3 roadster
    Quote Originally Posted by TexaZ3 View Post
    Yeah man, I managed to get the struts done, and still keep my face lol, wasn't to bad after I done the first strut, the other one was cake.
    Feb 2004
    VA
    When I last did the springs, I used 3 compressors instead of 2 to keep things even. I own a pair and for another from advance auto.
    Feb 2015
    Uniontown, PA
    1999 Z3 roadster
    Quote Originally Posted by workhurts View Post
    Yeah man, im planning on having an extra set to help stabilize the spring, but the larger fork style compressors are really cool, I learned that they allow you to decompress slowly enough, to align the bottom spring pad a snap, a very nice piece.
    Oct 2012
    Louisville, KY
    1997 BMW Z3 1.9L 5MT
    I used a set of HF compressors. The first strut I compressed as much as the tool would do, but the nut was still popped off and scared me. I thought then that I would not be able to compress the strut enough to get the nut back on, so I just took the old and new struts to a shop and let them do the job. The $40 was worth it.
    BMW MOA 696, BMW CCA 1405
    Oct 2013
    Augusta, GA
    1999 Z3 M-Roadster, 2007
    I did this job with the harbor freight compressors per nthor71783. I took it slowly and carefully. The compressors proved fully capable of handling my Z3M struts. A year later I was faced with doing the same job on my Toyota van. I took one look at THOSE springs and passed on the idea of using those wimpy compressors.
    Sep 2017
    Birch Bay, WA
    1999 BMW Z3 M Roadster
    Just replaced my front shocks with Koni Sports. Used the Auto Zone free loaner Mcpherson strut compressors. No issues.
    Dec 2007
    Great Dismal Swamp
    E36/7 E36/8x2 E46 F25
    M's are easy. With aftermarket springs, most times you don't even need a spring compressor. Konis into a regular Z3 / E36 is an entirely different game.
    /.randy
  1. Looking to buy some strut spring compressors
    By ErikO in forum 1992 - 1999 M3 (E36)
    Last Post: 05-03-2008, 12:41 PM
  2. WTB: strut spring compressor(s)
    By chairlamp in forum 1983 - 1991 (E30)
    Last Post: 01-17-2008, 01:58 PM
  3. Spring compressor needed to change struts?
    By Solidhead in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 09-27-2004, 11:01 PM
  4. New springs & struts, spring compressor needed?
    By cthulu703 in forum 1983 - 1991 (E30)
    Last Post: 08-06-2004, 07:40 PM
  5. '97 M3 struts and coil spring compressor for sale
    By hozehead4 in forum 1992 - 1999 M3 (E36)
    Last Post: 05-19-2003, 07:34 PM
