I have a 2002 325ci M54 2.5. I'm in need of new engine. Was wondering what engines can I drop in, hook up without any modifications or very little? I'm finding if diffucult
to find a good used 2.5 lol...
You could use:
- M52TUB28
- M54B30
Both would need the DME recoded to allow for the bigger capacity of the engine.
There is also a M52TUB25 (323i) engine that will not require any DME changes as it is the same capacity as your current engine.
If you buy a M52 engine, make sure that it the TU version with dual VANOS.
1999 2.8L Z3 Roadster,
2000 3.0L Z3 Roadster,
Recoding is not necessary but you will be leaving about 10 hp on the table without it. Still a net gain from the increase in displacement though.
Whatever you install, use your existing intake manifold, throttle body and injectors. It will run just as well as the 2.5 does.
