Results 1 to 16 of 16
Thread: Will E39 16x7 style 5s fit the E32? (tyres 205/50/16)
    Aug 2016
    Melbourne
    e30 318is, e39 528i, e32
    Hi guys,
    Will E39 16x7 style 5s fit the E32? They're shod with 205/50/16...
    Appreciate the help!
    Chris
    Aug 2016
    Melbourne
    HELP EXPERTS: Will E39 16x7 style 5s fit the E32? (tyres 205/50/16)
    Hi guys,
    Chris
    Aug 2016
    Melbourne
    HELP PLEASE EXPERTS: Will E39 16x7 style 5s fit the E32? (tyres 205/50/16)
    Hi guys,
    Chris
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    If you want to use E39 wheels (hub center = 74mm) you will need hubcentric, upgrades wheels and tires http://www.bmwe34.net/E34main/Upgrad...ls_upgrade.htm
    Standard is
    Hub center diametre: 72.5 mm
    Number of bolts: 5
    Pattern: 120 mm (See picture)
    Offset (ET): 20mm, The offset is the distance from the hub mounting surface to the centerline of the wheel. Wrong offset = bad handling.
    NW suburban Chicago
    hiss by my window
    Any E39 fitment wheel will need "hubcentric" rings as the E39 hub is slightly larger, 72.56 for E32 (and most other BMWs) vs. 74.1 for the E39(&X5?).
    I suspect that tire will fit too, albeit an odd choice.
    I see you have the same answer in all FOUR threads you've started, seems like a consensus.
    Jan 2016
    Ca
    2001 525it
    The hub centers would be a different size than the e32 I believe
    dworthy's Avatar
    Nov 2010
    Grafenwoehr, Germany
    16 220i 05 325it 05 M3
    Yes, but you will need a hub-centric ring as the E39 uses a 76mm while the E32 uses a 74mm hub, or is it 72mm? Either way you will need the ring.
    Darin
    Current:
    Past:
    79 525 euro Green/Green RIP
    M-Flight Member
    Dec 2005
    Baltimore, MD
    81 Scirocco-92 750il
    Use the aluminum ones, not the plastic ones. I had to put a piece of masking tape around my hubs to get them to stay on the hub and it has worked well for me for years.
    Melbourne, Australia
    '88 750iL, '01 530iT
    E39 wheels will fit with hubcentric rings as mentioned previously. 205/50/16 is a very small tyre for an E32 though... seems more like an E36 size. E32's usually run 225/55/16 or 235/50/16.
    1988 E32 BMW 750iL Bronzitbeige "....4372381"
    2001 E39 BMW 530i Sport touring Cosmosschwarz "....GL80561"
    Aug 2016
    Melbourne
    Thanks!
    Quote Originally Posted by jclausen View Post
    Aug 2016
    Melbourne
    Thanks!
    Aug 2016
    Melbourne
    e38 wheels with 235/60/16 on e32?
    Hey guys,
    Will e38 wheels with 235/60/16 fit on an e32?
    Appreciate the help.
    Jan 2005
    Japan
    I merged all your wheels/tire questions threads in E32 forum and wheel/tire forum here. http://www.bmwe34.net/E34main/Upgrad...ls_upgrade.htm
    The E38 wheels will fit, tires recommended
    16x7.5" Wheels:
    215/55-16
    225/55-16
    approved tire/wheel combinations accdg to the 1988 U.K. owners manual, steel wheels, alloy wheels, offset, tire sizes, it is all here https://750il.bmw7.hu/owners_manual/page_087.html
    Aug 2016
    Melbourne
    Thank you @shogun. Appreciate your expertise...
    The wheels are 16x8 (style 4s very nice) slightly different to what's covered in the guide. It seems 245/45/16 might work, to accommodate the width, without being too tall...What are your thoughts?
    Again, thank you. New to the e32 community.
    Quote Originally Posted by shogun View Post
    16x7.5" Wheels:
    215/55-16
    225/55-16
    Nov 2005
    Quebec Canada
    92 735iL (12/1991)
    I think you may need spacers with 245 tires. I run 225/55-16 on my 735iL and the inner tire rubs slightly against the strut, just enough to remove the dirt.
    Aug 2016
    Melbourne
    Thanks – a 215/55/16 sounds like the way to go.
  1. 4 OEM E39 16x7 style 18 w Michelin Winter
    By Jim3460 in forum Wheels and Tires
    Last Post: 11-04-2007, 01:22 PM
  2. will these style 5s fit??
    By e34life in forum 1988 - 1996 (E34)
    Last Post: 12-31-2006, 08:50 AM
