Results 1 to 6 of 6
Thread: bmw e46 318i vvt fault help!
    May 2019
    japan
    e46
    helllo i'm kugimoto I am not good at English
    My bmw is engine upset
    As a result of investigation by diagnosis, the fault code 2854 2731 appeared
    MAF has been replaced with new
    Is there a possible cause
    Eccentric shaft sensor?
    vvt motor?
    help!
    Mar 2019
    ATLANTA GA
    456 X3s
    Kugimoto:
    You lucky dog......
    see:
    https://r.tapatalk.com/shareLink?url...5&share_type=t
    Sent from my SM-J727T using Tapatalk
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    What tool did you use to scan the engine computer?
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    fault BMW BMW-10324 variable valves control - Sensor of the plausibility
    Fault Code: BMW-10324 ,Decimal code: 10324, Hexadecimal code: 2854, OBD code: P2854
    2731 - Camshaft Control Inlet https://www.bimmerforums.com/forum/s...-while-driving
    May 2019
    japan
    e46
    Thank you for your reply
    The code was 2783 instead of 2731
    pop up code is 2854 2783
    Code 2783 comes up after replacing the air flow sensor
    When the 2783 code goes up while driving, the mission is jerky and the mission check lamp lights up
    Diagnostic machine is a smart diagnostic
    https://www.bimmerfest.com/forums/ar...t-1040289.html
    Symptom is such a state, but I do not know solution
    May 2019
    japan
    e46
    偏心軸センサーを交換することで問題は解決しました。
    みんなありがとう
  1. 2003 BMW E46 318i Auto - Help/advice - PCV/blowby problems
    By neroau in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 07-10-2018, 12:56 PM
  2. Replies: 2
    Last Post: 12-25-2016, 09:16 PM
  3. Replies: 1
    Last Post: 04-14-2016, 06:16 PM
  4. Valvetronic VVT EML Limp Home Issue Codes 285E 2865 - BMW e46 318i 2002 [FIXED!!!!!]
    By Pat7 in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 04-13-2016, 02:21 AM
  5. bmw e46 318i help plz,
    By Sven77 in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 08-19-2008, 09:29 AM
