Dinan Supercharger bracket
Vortech V2 supercharger
Bulldoge 6" 6 rib brank pulley, 3.13 Supercharger pulley ( this combo is about 13 psi approximately 350whp on an S50)
Bosch 42lb/hr injectors
Upgraded aluminum bypass valve
RMS aftercooler, bosch water pump, ebay air-to water heat exchanger that fits behind a late valence with very minor modification.
Modified dipstick tube for oil return, modified radiator with a 90 degree on the top hose, and an overflow return on the passenger side. I have every nut, bold and, stud you need to make this work in an e30, but nothing has been modified to where you couldn't put this straight into an e36 also.
I have a MegaSquirt V3 Pro plug and play professionally tuned for this set up that I would be willing to sell with the kit but not separately. $5100 obo for everything including the megasquirt (obd1 only). $4000 without MS. We can work on the price of you're putting it in an e36 and don't need the e30 specific parts.
Raceland headers brand new, never tried to install them - $200 .
14point7 idash data logger, single wideband controller, wideband sensor not included $115 Very simple and versatile datalogger, although 14point7 doesn't sell them anymore
Raspberry Pi Dashboard 7" $275 - includes a wireless mini keyboard, a two different 12v to 5v power supplies one of which will properly shut down the Rasberry Pi when you turn the car off, and an enclosure for everything
806 3.5" Euro MAF good working condition $80
Aquamist HFS-3 PWM water/meth injection kit, with baffled tank setup. I bought this used and never installed it -$550
6 cylinder direct port water/meth kit. new but the bags have been opened http://www.aquamist-direct.com/806-4...his-shop-only/
110cc jets - $325
Racetronix / Lucas 42# fuel injectors. These have only been in the motor at idle, then the tuner informed me that I needed Bosch injectors. $270 new from racetronix- $215
Make an offer- obd1 ICV,
generic Amazon boost gauge with green or white backlights,
AEM uego without the wiring harness' or a sensor.
Generic ebay catch can, one of the hose barbs was damaged from the factory, but functionality is unaffected.
Feel free to ask questions or for any other pictures you want
link to pics on FB Marketplace https://www.facebook.com/marketplace...9649302421769/
pmed
