Results 1 to 25 of 25
Thread: New z3 intro, pics, and the way forward.
    Feb 2019
    Bay Area
    2000 BMW z3
    So a few months ago I see this z3 on Bay Area CL. I was searching for a drop top 5 speed to replace my beloved e30 325is I had to sell when I went to fly for the airlines. Guys asking 1500 and says it runs but needs work and says he doesnt think it’s the head gasket. I think to myself; it’s worth checking out. Owner send me a video of it running and not over heating. It’s also a 6 and not the 4 cyl he has it listed as.
    My interest is peaked.
    After looking at it it’s clear rodents have been living in it. But it moves and stops under its own power just won’t rev over 2k rpm. I offer him $400 expecting him to counter and is to settle around 5-6. He accepts the 4! I use girlfriends aaa to tow it 80 miles home.
    It begins.
    Capet is soaked.
    I pull the code and find it’s for the throttle body( can you guess where this is going?)
    I pull the air box during the oil change
    (I love putting fresh fluids in old bmws)
    And find the throttle is simply stuck
    I pop it loose w my finger and clean it.
    It runs great!
    Rats did chew the o2 sensor on the chassis side. In a happy accident I ordered the precat o2 sensor which had the connector for the post car o2 sensor. I cut it and splice in. A hack job but good for now.
    Diff fluid looks new. Didn’t even need to change it.
    Btw the car is a 2.3 which I soon learn is a m52tu.
    Vanos doesn’t need rebuild. And coming from the e30 I am impressed by the Siemens engine management.
    Car passes smog and runs great but is all over the road. I bought some ds2s and new tires and it tracks amazing. Didn’t even need an alignment.
    I am blown away. And can’t stop laughing as I wheel around town in my new roadster.
    I fall in love.
    Current issues.
    1. Abs light on intermittently. I have one short and one long wheels sensors to swap out and try to fix abs
    2. Car is now cutting out at wot above 5000rpm code says vehicle speed sensor. Could this be because I am running a 235/45/17? I know it is oversized slightly but I like the additional sidewall.
    3. This could be related to the other two but I think the water may have gotten to the yaw sensor (drivers footwell right?)
    Is this causing my inop dsc?
    4. Windows don’t work.
    5. Heater doesn’t work.
    I don’t miss my e30 anymore. It’s cool having a z3 as I can feel it’s the next generation but it still has the e30 rear. What a cool car. Eventually I will get a m roadster but I really want to get to this car better both to appreciate the m more and learn the chassis.
    So that’s it for now I wanted to
    Introduce myself and the car. Looking forward to leaning more about obd2 (which so far, is great) and driving. This is the best driving car I’ve ever driven. and it’s on stock springs.
    Nov 2018
    Broad Run, VA
    1998 Z3 2.8 5sp
    Congratulations, and a great platform to start from. Love the wheels!
    ‘98 Z3 2.8 roadster, Montrealblau/tan 5sp, M50 manifold, AFE intake, SuperSprint catback, Bilsteins, BAVAuto sport springs, Style 42 BBS
    Oct 2018
    West Bend, WI
    MRoadster,Tacoma,DR650
    Congratulations. Looks really nice on the outside.
    Check for cracked subframe spot welds on floor in trunk. Don't want the rear end falling off.
    Sep 2018
    Houston, TX, USA
    1999 BMW Z3 Coupe 2.8
    Seems like a great deal. Congrats sir!
    Boiling Springs, PA
    '02 Z3 3.0i 5 speed
    For $400 how can you go wrong!
    Sep 2003
    kansas city
    98 Z3, 01 330i, 07 328iT
    My drivers seat was doing something similar. I bought a matching passenger seat at a salvage yard for $200 and swapped the seat bottom over the drivers side. I also re-dyed all the leather in the interior so it all matched.
    Aug 2017
    Quote Originally Posted by Ghostfalcon View Post
    2. Car is now cutting out at wot above 5000rpm code says vehicle speed sensor...
    1. Z3's are famous for dying ABS modules, worth to do some research on that. Having someone resolder the module is relatively cheap, easy to do and often fixes all issues.
    2. This is because of the ABS fault, when you drive around without the ABS module in place (waiting for it to return in the mail) you get the same error code.
    3. Yes, the yaw sensor is under the driver seat and they often die in cars that have a leaky convertible top.
    4. No idea
    5. Do you have heat at higher RPMs (2000+)? Does it reach operating temperature relatively quick? Cheapest fix would be that the cooling system needs a bleed, otherwise the thermostat might be suspect. Check the coolant level in the expansion tank when cold.
    Feb 2009
    Charlotte, NC/Denmark
    2K Z3 2.8
    Welcome!
    Looks like you scored a hell of a deal.
    Time to invest in a cheap airbag reset tool to eliminate the other warning light you're dealing with.
    Zed's dead baby. Zed's dead.
    Feb 2019
    Bay Area
    2000 BMW z3
    No heat any any rpm. I’m pretty sure the dial isn’t connected to anything.
    Can the yaw sensor be repaired?
    Where can I get a abs module? It’s normal for it to be intermittent?
    There are some loose welds in the trunk. Is it totaled?
    Feb 2019
    Bay Area
    2000 BMW z3
    Quote Originally Posted by CoconutPete View Post
    Welcome!
    I’d use it Once and throw it away. Hoping someone in the Bay Area has one.
    Oct 2018
    West Bend, WI
    Not totalled, but needs attention. Randy Forbes reinforcement kit is the number one solution. PM him on this forum for details.
    Feb 2014
    Galt,CA
    2002 M Coupe
    The Yaw sensor can't be repaired, but you can buy replacement ones on eBay. It is located under the driver's seat, you'll probably need to remove the seat to get to it. Make sure you find the electrical connector(s) to the seat, there may be one or two. Don't turn on the ignition while the seat is disconnected!
    Marty
    Feb 2019
    Bay Area
    2000 BMW z3
    I already did that, see pic #2
    Am I reading this correctly the abs module can cause an intermittent abs light and a p500 vehicle speed speed sensor code
    Whats the fix for the abs module? does anyone perform this service?
    This car is so buttery smooth, 3rd gear bliss...it really is a generation newer and more refined than the e30. Im so spoiled
    Aug 2017
    Yes, you're reading that correctly. Read the codes out of the ABS module with a BMW scanner, that'll tell us what is wrong with it and how to proceed.
    Feb 2019
    Bay Area
    2000 BMW z3
    Can someone recommend a shifter upgrade? is the z4 shorter throw im looking for a +1 upgrade so slightly shorter, but noticeable. My car has the getrag though not sure the model, i heard these came w zfs as well? what the preferred trans and why?
    New England, USA
    2000 2.3 Z3, 2007 328xi
    I like ZHP weighted/shorter one: Search:
    BMW M ZHP SHIFT KNOB E30 E36 E46 E28 E34 E39 Z3 M3 5-SPEED
    (edit - looking at the pic it looks like you might already have it?)
    you probably want to invest in a USB Diagnostic cable.
    yep, it's a E36/7 which really is only the front end E36 gen, the E30 rear end is what really makes this car unique in many ways including some of those broken spot welds, inspect your diff mount area too!
    yep, 3rd gear is quite magical, I think you can do 10-80, the smoothness is the m52tu dual vanos and DME ECU from E46 gen.
    I have the getrag - think it was standard on 2.5L, and bigger engines got the ZF. My getrag with OG clutch at 157k has been problem free - do recommend and enjoy Amsoil for smoother shifting.
    “Great wisdom is generous; petty wisdom is contentious.” 无为
    Fort Worth, TX
    E36M3/E46M3/E39M5/E63M6
    Is your brake switch good? Could cause ABS light as well.
    Hell of a deal!
    E36/8 2000 M Coupe Cosmos Black/Black
    Shark, Conforti CAI, B&B Exhaust, H&R, Bilstein, AKG Subframe/Diff, UUC TME Red/Caps, Swapped Front Hats, Ice>Link.
    Mar 2008
    Northern Virginia
    2000 M Roadster
    congrats! Handsome car.
    2000 M Roadster (Estoril Blue)
    2018 Jeep Wrangler (Daily driver)
    Feb 2019
    Bay Area
    2000 BMW z3
    Quote Originally Posted by TexaZ3 View Post
    Hell of a deal!
    Could anyone expound on this?
    I’m thinking about going to the dealer for a rectal scan.
    Aug 2017
    Brake pedal switch, they sometimes go bad and cause the cruise control to not work anymore. I guess they could disturb ABS function too. That switch will show up in the engine computer (DME) error memory as "brake pedal switch signal unplausible" or something like that if it is faulty.
    Feb 2019
    Bay Area
    2000 BMW z3
    So I just came back from mechanics. He couldn’t get the scanner to talk to the abs. Nothing. Would a faulty control unit cause this? I also DID get the brake pedal implausible code.
    Feb 2019
    Bay Area
    2000 BMW z3
    Oh forgot to mention we couldn’t reset the steering angle sensor
    Also my lights, and I mean the entire electrical system pulses; headlights and all dash lights pulse in intensity. Could this be a bad alternator? If so is it just the voltage regulator or do I need a new group of windings?
    Aug 2017
    I had a very slight flickering in my dash lights and overall weak voltage, it was the voltage regulator on the alternator. Wasn't noticeable in the headlights though. The voltage regulator is easy to replace when the alternator is out of the car. The diode board and the windings usually never need replacement.
    What does a voltmeter connected to the car while it's running say, is the voltage fluctuating a lot?
    Feb 2019
    Bay Area
    2000 BMW z3
    The headlight and all dash lights dim noticeably. I haven’t checked the voltage but it’s pretty clear it’s fluctuating. I read in another thread alternator can cause these codes but it was for the “normal” e36 chassis
    In summary
    Codes present:
    Brake pedal travel sensor disagree
    Vehicle speed sensor.
    Symptoms :
    Dsc abs light
    I feel like this could be like 3 different problems each caused by 3 different failures.
    I’m concerned the scanner couldn’t talk to abs unit, I hope the rats didn’t get to some sort of data transfer wire
    I’ve never enjoyed a car so much as this one. Even w the lights. I’m a pilot, and I like all my systems to work.
    Feb 2019
    Bay Area
    2000 BMW z3
    Quote Originally Posted by me77 View Post
    Yea that’s the code.
    Is this the switch that turns on the brake lights? Because they work.
  1. So the new Z3 is on it's way to my garage as we speak
    By healeydays in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 05-25-2017, 06:47 PM
  2. A new Z3 SSK (pics and results)
    By Mr Estoril in forum 1992 - 1999 M3 (E36)
    Last Post: 09-25-2011, 12:25 PM
  3. 328is: Time for new pics (56k no way)
    By Bimuh007 in forum BMW Rides & Events
    Last Post: 05-30-2008, 10:39 AM
  4. New member intro w/ pics
    By Nlped in forum 1987 - 1991 M3 (E30)
    Last Post: 09-13-2006, 02:06 AM
  5. New member- just thought I'd post up a few pics. . .*56k no way*
    By FryingPan in forum BMW Rides & Events
    Last Post: 09-15-2005, 03:19 PM
