Results 1 to 2 of 2
Thread: MHD link_ Bad HPFP?
    May 2019
    Cda idaho
    2011 335i sedan
    MHD link_ Bad HPFP?
    Run on my 2011 335i just flashed to MHD stage 1 91 octane. now my fuel pressure is really fluctuating and car goes lean when it does. lots of timing corrections where the psi drops. This is proof my HPFP is toast right? Or could my LPFP be the problem? Thanks guys.
    https://datazap.me/u/erzenble/2011-3...58&tmax=100.70
    May 2017
    Ontario, Canada
    335i E93 N54
    Hi Erzenble,
    I recommend working with MHD directly regarding their tune and your car. They'll be more familiar with their logs and such.
    I'd chime in, but I'm JB4 all the way. Fantastic performance, flexibility, logging and support.
    I tried to follow the MHD log, but I find that UI so messy.
    What boost is MHD Stage 1?
    I have to run 94 Octane with a BMS FMIC to support 15 PSI, and am currently adding WMI to help with timing and cooling of IATs.
    Also, depending where you buy gas, 91 can really fluctuate (Pioneer).
    It also takes the DME a few pulls before it identifies the correct Octane and adapts.
    There can be a big conversation. Or maybe it is simply HPFP. Though, it's not common to tap this out below 15 PSI, unless it was already failing.
  1. How to tell if front strut mount is bad
    By qwickm3 in forum 1992 - 1999 M3 (E36)
    Last Post: 03-17-2017, 10:11 PM
  2. 2009 135i HPFP bad.
    By Prometheus135i in forum 1 Series & 2 Series (E81, E82, E87, E88, F20, F22, F23, F40, G42)
    Last Post: 08-29-2014, 01:24 PM
  3. Power/speed shifting bad???
    By xjeeper in forum 1992 - 1999 M3 (E36)
    Last Post: 04-17-2001, 11:30 PM
  4. Sound - bad/loose Guibo?
    By Alex '94 325i in forum 1991 - 1999 (E36)
    Last Post: 04-13-2001, 11:23 AM
  5. Bad Passenger Head rest
    By JamesB in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 03-27-2001, 10:10 PM
