Results 1 to 5 of 5
Thread: DSC and Park Brake Light On
    Dec 2009
    New Glasgow, Nova Scotia
    1998 740iL
    I have a 1998 e38 (740iL).
    Car was garaged all winter and after replacing battery,two warning lamps on my instrument cluster display - Parking Brake On and DSC Light On. The check engine light is not on and there are no codes that display on my Creatdor C301+ scanner.
    Car runs fine and there is no resistance to roll when parking brake off yet Parking Brake dash light remains on.
    Pressing and holding the DSC button has no effect in clearing the DSC dash light.
    The brake fluid resevoir shows brake fluid at the max line.
    I have DIS, INPA and all cabling but am a novice at its use. I am hoping someone might shed some light on how to proceed to clear these lights.
    Thanks,
    May 2013
    Rochester, NY
    2001 740i Sport
    Try setting the parking brake, releasing it and then while still holding the release lever, pull up slightly on the pedal. Mine doesn't return the pedal the last 1/4" or so, leading to the light being on (but no brake drag) unless I pull up on the pedal.
    Feb 2009
    KC North, MO, USA
    1996 740iL
    May just be a wheel speed sensor. INPA should pin it down.
    Dec 2009
    1998 740iL
    I tried lifting the park break pedal with my foot while in drive but the park brake light reamins on.
    All four wheel speed sensors register positive movement in INPA.
    Jan 2013
    California
    2001 E38 iL
    Don't judge the brake fluid level by looking on the outside fill line. Remove the cap and filter screen and peek inside. I've run into that issue before and it was always the fluid even when it looked full from the outside
  1. ABS, DSC, parking brake lights on after Coolant Flush
    By anaElBasha in forum 2002 - 2008 (E65, E66)
    Last Post: 08-24-2018, 07:49 PM
  2. ABS, DSC, parking brake lights on, help
    By ak745li in forum 2002 - 2008 (E65, E66)
    Last Post: 02-21-2013, 08:57 PM
  3. Park Brake light has a mind of its own
    By FritzE30 in forum 1983 - 1991 (E30)
    Last Post: 11-14-2005, 12:29 AM
  4. Need Help DSC, ABS and Brake Light came on today any ideas
    By pass427 in forum 1988 - 1994 (E32)
    Last Post: 10-26-2005, 06:39 PM
  5. Parking brake light is on, on dash
    By RaNDaLLsAxToN in forum 1991 - 1999 (E36)
    Last Post: 11-17-2004, 06:41 PM
