Results 1 to 6 of 6
Thread: Convertible switch going bad?
    Feb 2009
    harrisburg pa
    1994 325ic, 2012 328ic,
    2012 328i convertible switch giving me red light faults when trying to lower. If I stress the switch slightly differently it corrects. No problems going back up. Anyone else have this switch go bad?
    Working on the 325 reminds me how much I LOVED my old Jeep Wrangler. A bus ate it.
    May 2017
    Ontario, Canada
    335i E93 N54
    I've not seen anything similar with mine.
    What you describe sounds like it is a two stage switch to open, with the first engaging the light, then the second starting the open sequence.
    It's not this way though. The light comes on, then after approx 1~ second, the open sequence begins.
    Perhaps it's slightly faulty and it engages, then disengages, then engages, and when you pull harder on it, the 'open' signal remains constant.
    Walking through my own thoughts there, if it's as I describe, it must be an poor contact inside the switch.
    Test with the key-fob to ensure it doesn't behave similarly.
    Let us know the resolution.
    Feb 2009
    harrisburg pa
    Thanks. Still new to the e93. How do I use the key fob to raise it lower the top?
    May 2017
    Ontario, Canada
    335i E93 N54
    Quote Originally Posted by doclees View Post
    In my 2008, N54, E93;
    Close proximity to the car
    Doors closed, Trunk set ready for dropping the hard-top
    Press and Hold the 'unlock' button, after 1-2 seconds the sequence will start
    I have to keep my finger on the unlock button until complete.
    Lock, following the same sequence will close it.
    I have to be within 5' of the car to do it.
    I've heard of some where you press unlock 4 times and it opens by itself. Mine does not do this.
    Feb 2009
    harrisburg pa
    Thanks I'll give it a try when I get home.
    May 2017
    Ontario, Canada
    335i E93 N54
    Curious how it worked out for you.
    Also, if you test pushing unlock 4 times quickly, if it drops the top for you. (I'd be so jealous)
  1. Has your FDK 80/88 fan switch gone bad?
    By Mad Dog 20/20 in forum 1992 - 1999 M3 (E36)
    Last Post: 05-09-2006, 03:50 PM
  2. bad brake curcuit switch OR bad tail lights?
    By punkska20 in forum 1992 - 1999 M3 (E36)
    Last Post: 05-15-2005, 10:19 PM
  3. Converter has gone bad twice in 6 months
    By dualfragment in forum 1991 - 1999 (E36)
    Last Post: 11-05-2004, 11:50 PM
  4. added (RF 2 way) 5 1/4's in the kick panels and in rear of a convert, sound still bad
    By toofast4U in forum Car Audio & Electronics sponsored by Bavsound
    Last Post: 04-26-2004, 09:36 AM
  5. how to tell if catalytic converters are going bad?
    By psk145 in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 09-05-2002, 02:29 PM
