Results 1 to 6 of 6
Thread: M20 swap question
    Apr 2016
    Oxnard, CA
    1986 BMW 318i
    M20 swap question
    So im currently looking for a m20 to swap into my 318i euro spec, i plan on stroking it and putting a nice size turbo on her. Should i stick to the m20b25 or could i use the 2.7 eta?
    86 Bronzit 318i m10b18 coupe (EuroSpec), GC coilovers, DOEC 40 Carb, Wilood BBK
    Oct 2003
    Seattle
    99 M3
    In 1988 BMW created the Super Eta …2.7L, special pistons, the “I” head and engine management.
    You could run the standard Eta 2.7L block and pistons, with “I” head and engine management. This combination would have lower compression, perfect for Turbo application.
    Apr 2016
    Oxnard, CA
    1986 BMW 318i
    So if i snagged a 2.7 i could swap the 2.5i head on or is there a 2.7i head? Or would it be a smarter move to go with a s5x swap im looking to get 500-600 hp would that be possible with. 2.9 stroker and a 6262 turbo? Cause i do know that parts for the s5x setup get expensive fast.
    Oct 2003
    Seattle
    99 M3
    M20 swap question
    If you are looking for that kind of power I would consider an M52, these are plentiful and inexpensive. You will have to open it up to drop static compression for turbo application.
    ‘Playing’ with any BMW engine seems to get expensive quick!
    Dec 2005
    corpus christi, texas
    No e30s, again :(
    but, just fyi, the 325e stuff is plug and play in to an m10 318 car. the electrical uses the same plugs so your engine harness will plug right into the body so that makes one spot easier as you don't have to buy, or make, an adapter
    No e30s again.
    Joliet,IL
    87 325is 96 GMC Suburban
    Why not stroke the m10 and install the turbo?
  1. m20 swap questions...
    By HeathMO in forum 1975 - 1983 (E21)
    Last Post: 10-12-2016, 07:15 PM
  2. 1984 E30 318i to M20 swap questions.
    By Bricktop42 in forum 1983 - 1991 (E30)
    Last Post: 05-09-2015, 01:12 PM
  3. Carbed 323i m20 Swap Questions
    By Chad E36 in forum 1975 - 1983 (E21)
    Last Post: 04-13-2013, 11:06 AM
  4. M20 Swap Questions
    By e21gangsta in forum 1975 - 1983 (E21)
    Last Post: 01-28-2008, 05:51 PM
  5. M20 Swap Question into a pre 80
    By blitzed310 in forum 1975 - 1983 (E21)
    Last Post: 06-06-2007, 06:23 PM
