Results 1 to 8 of 8
Thread: IE Subframe Bushing fitment issues
    Oct 2005
    Scotts Valley, CA
    2000 Z3 M Coupe
    Exclamation IE Subframe Bushing fitment issues
    While I was under the car to fix the CSB, I checked my subframe mounts -- sloppy and torn. I ordered a set of the Ireland Engineering Subframe mounts. Sadly, they've changed the top flange, it's only 0.395", like the bottom, not the 0.500" it used to be. This results in the top half floating when mounted.
    Here's what it used to look like (stolen from another post ):
    Here's what it looks like on the car:
    It does compress a bit when everything is tightened down, but you can still see light all the way around and the subframe readily moves up and down.
    I went back and forth with IE via email and phone for a week; I explained the issue with the above photos. Finally, they said:
    - "I'd install it on my car"
    - "It'll be fine once you tighten it up"
    - "You can send it back if you don't want to install it on your car"
    Since I had already installed them a couple of times and figured I'd lose another $15 on shipping and risk a complete loss, I made a couple of aluminum shims, about 0.090" thick:
    Works great, puts a bit of preload on the bushings, no slop.
    If I had it to do over, I'd go with the AKG bushings. They appear to have the larger top flange, and you can choose the durometer.
    Anyway, just a head's up...
    Sold: 98 M3/4/5 Techno Violet
    Sold: 07 Cayman S
    Sold: 98 Z3 M Roadster
    00 Z3 M Coupe: TC Kline SA, Vorshlag Camber Plates, 255/35/18(F), 295/30/18(R) on APEX ARC8's
    SW Florida
    99-01 M Cpe & Rdts, X5M
    lOOKS LIKE YOU HAVE THE ONES FOR AN e30__DID YOU ORDER THEM ONLINE, OR TALK TO A HUMAN, VIA PHONE...?
    (sorry for the caps__NOT retyping )
    Oct 2005
    Scotts Valley, CA
    2000 Z3 M Coupe
    I ordered online, but I have 9 emails, four phone calls, and the *first* thing they did is confirm the vehicle. I sent the pictures, and multiple techs claimed they reviewed them. That would be sad, though
    Edit: To be clear, all the other measurements were identical. Just the top half had issues, leaving the hex part "proud". Oh, and I had an excuse to use both my mill and my lathe, so there's that!
    Sold: 07 Cayman S
    SW Florida
    Quote Originally Posted by weenerdog View Post
    That always makes for a good day!
    Oct 2018
    West Bend, WI
    MRoadster,Tacoma,DR650
    My IE bushings just arrived. They included two big flat washers that are plated steel, but look like your aluminum washers. Didn't you get the washers in your shipment?
    Jul 2012
    Henderson, CO
    2000 M Roadster
    I have a set on order. Curious now to see what I get.
    Weird how IE seems to making changes so many years after the fact
    Late response to bad wind about their bushings disintegrating? Or just trying to stay relevant in the marketplace (a LOT of new E30 stuff out there)
    PRICE CUT on ALL FABRICS
    Oct 2005
    Scotts Valley, CA
    2000 Z3 M Coupe
    Yes, there were two big washers, but they apparently sit above the hex part on the bolt. And the original washers go on the bottom. I assume. There's enough room for error that a simple page of instructions or a diagram would have been helped.
    Sold: 07 Cayman S
  1. IE Subframe Bushing: Improper Installation or Design Flaw?
    By moonluv810 in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 04-15-2016, 05:22 PM
  2. IE subframe bushing time estimate
    By ///Mmelmann in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 02-02-2006, 10:00 PM
  3. Help - I can't pull up the site for IE subframe bushings install
    By M5inVA in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 09-16-2005, 05:33 PM
  4. IE subframe bushings increase noise?
    By mcoupe197 in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 07-11-2005, 03:39 PM
  5. major problem after installing IE subframe bushings - please help
    By aristid in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 05-28-2005, 01:24 AM
