Results 1 to 7 of 7
Thread: Volvo brake upgrade...calipers not releasing
    Apr 2015
    Corpus Christi
    1996 750iL, 1982 320
    So my calipers on my 82 320 were not releasing. Took them apart, cleaned them up, reassembled, bleed them. Frozen again. So I figured as long as I needed new calipers might as well upgrade to the volvo brakes I read about on this forum. Got them installed, bleed. Not releasing. Probably not frozen in the 1st place.
    Any idea if the proportioning valve can cause this or master cylinder or rubber lines?
    Jun 2014
    northern michigan
    95 M3 - 06 X5 3.0
    A master cylinder can cause it if it is adjusted incorrectly to where the piston does not come fully back to its stop after you hit the breaks, as in if the rod adjusted too tightly against the brake pedal, you have to leave it some slack to fully come back like you would a motorcycle clutch..
    What Volvo calipers are they exactly? Are they by chance the early 90's 240 4pot calipers with the single brake line?
    E36 M3 S50 - E53 X5 M54 - 1980 Porsche 931 - 2001 Impreza RS25
    Apr 2015
    Corpus Christi
    I'll check that out. Thanks. the Volvo brakes have to lines so I had to make a T fitting.
    Jun 2014
    northern michigan
    95 M3 - 06 X5 3.0
    Right, those are the earlier non-abs cars with 2 lines.. I think their are also narrow disk and wide vented disk versions of the Volvo 4pot calipers but they all mount the same..
    I'm just interested because I have Volvo calipers on my 931 and if they fit the e21 too then I guess that means that all the early 944 caliper options work on the e21, and vice versa, which is interesting..
    Apr 2015
    Corpus Christi
    Not it. I adjusted it all the way out and the brakes are still not releasing.
    Mar 2013
    Santa Rosa, CA
    1981 320i silver
    .. or rubber lines?
    Yes the rubber hoses COULD cause that, if they are very old. Hopefully you've replaced them?
    Feb 2009
    District Nine
    sold 78 BMW 320i
    Quote Originally Posted by okieflats View Post
    As if pieces of rubber were plugging the passages?
    Isn't the pressure/proportioning valve for the rear brakes?
    You can try process of elimination from the pedal (as already suggested), all the way down to the bleeders.
    Tbd
  1. front brake caliper not releasing
    By MYM50 in forum 1991 - 1999 (E36)
    Last Post: 01-02-2016, 04:40 PM
  2. volvo brake upgrade improvement
    By dhlthr in forum 1975 - 1983 (E21)
    Last Post: 12-11-2009, 07:17 PM
  3. question about volvo brake upgrade
    By bflan2001 in forum 1975 - 1983 (E21)
    Last Post: 10-18-2007, 12:27 PM
  4. Frozen front caliper... :( Volvo brake upgrade?
    By vtgti in forum 1975 - 1983 (E21)
    Last Post: 05-15-2007, 01:46 PM
  5. Brake upgrade or not?
    By PGH540BIMMER in forum 1996 - 2003 (E39)
    Last Post: 01-16-2007, 08:02 PM
