Results 1 to 7 of 7
Thread: Oil level correct?
    Jun 2008
    Dallas, Texas
    '14 550/M, '03 540/M
    Oil level correct?
    I changed the oil and filter today and put exactly 9 qts of Castrol Synthetic. Afterwards I
    measured the oil level and it still shows halfway between the Max and Min.
    shouldn't it show Max?
    Jan 2016
    Ca
    2001 525it
    Well it could that max min represents 1 qt, add a bit at a time but half way is ok
    Jun 2008
    Dallas, Texas
    I have changed my own oil for decades. The difference between the Min and Max on a dip stick is 1 qt. so I assume the electronic measure is the same.
    Ironically the Owners Manual does not publish the oil capacity of the engine, but I found this in an online service manual source, so the measurement is correct, and 9.51 qt is the engine capacity.
    (northeast) Indiana
    15 650ix GC & 14 X5 50i
    Quote Originally Posted by yodamel View Post
    Ditto what the others said above. Remember that your car is German...and the oil capacity recommendation from BMW was for 9 LITERS (not quarts). So if you are using quarts...you need to do the conversion which would require 9.5 quarts.
    The measurement you see in iDrive would then be correct in that the oil capacity between the MIN & MAX measurement is approx 1.1 quarts. When you take into account that you were approx 1/2 quart short...the iDrive oil measurement is correct.
    As you can see in the pic below from my X5's owners manual...historically the difference between the min & max lines on the dipstick has been 1.1 quart/1 liter...I'm sure the same has carried over to the new gen BMWs that don't have dipsticks...but an iDrive screen/display.
    (northeast) Indiana
    Here's some additional info from the BMW TIS about total oil capacity and the difference between the MIN/MAX line on the iDrive display:
    Jun 2008
    Dallas, Texas
    Quote Originally Posted by Qsilver7 View Post
    thank you. my previous post was from the same website and I'm good now. It has 9.51 quarts and is at the Max. I just mis-read what someone had posted before (qts vs liters) and put 9 qts that was was why it was halfway. (that's a great website btw, I'm very thankful that is online)
    (northeast) Indiana
  1. Oil Level Light Stays On but Level Is Correct
    By BMWtyro in forum 1983 - 1991 (E30)
    Last Post: 07-27-2018, 08:44 AM
  2. Replies: 47
    Last Post: 07-22-2014, 10:57 PM
  3. Correct Transmission oil level E39 1997
    By Ballard in forum 1996 - 2003 (E39)
    Last Post: 05-09-2008, 12:40 PM
  4. Oil Level is high and Lifters ticking?????
    By Quake in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 11-18-2001, 02:23 PM
  5. Oil Level.....
    By HK_M3 in forum 1992 - 1999 M3 (E36)
    Last Post: 10-13-2001, 06:21 PM
