Results 1 to 7 of 7
Thread: HELP - Front Diff Issues F30 - VIDEO
    May 2019
    MA
    911, 320I XDrive
    Noticed a hum from the front end early last week. Especially noticeable on decelerations. Mid week noticed a oil leak had developed. Got the car in the air yesterday to see a coating of oil on much of the driverside only in the area of the diff.
    Clean the area up and change out the fluid. The spent oil had a shitload of metal in it, very fine.
    Drive 10 miles and let the car sit to try to spot where the leak is.
    Appears as though it is coming from the output flange to the driveshaft. I'm guessing that its being whipped out when driving explaining the driverside having oil everywhere and the passenger clean.
    Questions:
    Is there a serviceable seal there ?
    Is the amount of play seen in the video normal ? the play is NOT coming from the u joint.
    https://youtu.be/O_3-luJJoaA?t=7
    Jan 2016
    Ca
    2001 525it
    Just find a good used unit it would be quicker and easier solution. Call lkq
    May 2019
    MA
    911, 320I XDrive
    Unless I have to pull the diff to service, not sure how that's an easier solution.
    Now the fact the diff maybe toast does make me think you may be onto something.
    That said, really don't want to drop the money and time/labor into swapping the diff if I can get some more life outta the one in the car.
    Jul 2004
    Houston, TX
    36 Cylinders
    They don't usually go bad. So you should just put in a used one with the same gear ratio as your rear and be happy.
    -Abel
    - 2000 Z3: Many Mods.
    - 1999 S52 Estoril M Coupe
    - 2016 Mini Cooper S
    May 2019
    MA
    911, 320I XDrive
    Anyone know where I can find the technical documents for the differential removal and reinstallation ?
    Jul 2004
    Houston, TX
    36 Cylinders
    -Abel
    May 2019
    MA
    911, 320I XDrive
    Cool... Thanks for the link.
  1. Help! Front end Issues
    By pfregeolle in forum 1995 - 2001 (E38)
    Last Post: 05-29-2013, 02:50 PM
  2. help- front diff bolt doesn't line up
    By PhYrE in forum 1992 - 1999 M3 (E36)
    Last Post: 02-22-2007, 10:51 AM
  3. Help....someone have a front diff. bolt?
    By dcroghan in forum 1992 - 1999 M3 (E36)
    Last Post: 01-12-2007, 04:49 PM
  4. HELP!!! 325IX Front Diff Seized!!
    By Milhouse in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 01-05-2002, 02:25 AM
  5. HELP!! 325IX Front Diff Seized!!!
    By Milhouse in forum 1983 - 1991 (E30)
    Last Post: 12-31-2001, 08:40 PM
