RM European Auto Parts
Results 1 to 2 of 2
Thread: Do I need to use Sealing Compound on my rocker cover?
    Jan 2019
    Leicester, Uniter Kingdon
    1995 840ci
    Hi All,
    I'm replacing the rocker cover gaskets on my 840ci soon, so I've been checking the maintenance manual ahead of doing so.
    It says to use 'rubber anti-friction compound e.g. Glycerin' when fitting the gasket to the cover - I presume that I can use red rubber grease for this?
    It also says to 'coat the contact faces of the joint with Hylomac SQ 32M** liquid sealing compound'. Is this necessary and, if so, can anyone recommend a product (available in UK)? I've googled 'Hylomac' and it doesn't return any results.
    Thanks in advance
    dworthy's Avatar
    Nov 2010
    Grafenwoehr, Germany
    16 220i 05 325it 05 M3
    Normally Black RTV works in the corners of the half-moon on the gasket. Just put a little in the corners, and you will be good, just don't go over board.
    Darin
    Current:
    Past:
    79 525 euro Green/Green RIP
    M-Flight Member
  1. Gauging Interest: Long Pins needed when using OEM Mesh Windscreen w/ boot cover
    By lokijibber in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 06-15-2012, 08:08 PM
  2. Do I need to use valve cover seal washers?
    By CMG in forum 1992 - 1999 M3 (E36)
    Last Post: 12-31-2007, 04:59 PM
  3. i need a used e34 M5 clutch disk
    By odortiz in forum 1988 - 1996 (E34)
    Last Post: 08-28-2002, 09:44 PM
  4. Used R-compound tires and NEW Forgeline RS wheels for sale
    By Vader M3 in forum BMW Parts For Sale
    Last Post: 01-26-2002, 08:02 PM
  5. Need cheap used 235/40/17's!
    By Ben 93 325is in forum BMW Parts For Sale
    Last Post: 08-28-2001, 12:55 PM
