Results 1 to 9 of 9
Thread: OffCamber Motorsport Wilwood Brake Kit
    Apr 2014
    Slidell, LA
    Many
    SOLD
    SOLD
    SOLD
    Used OffCamber Wilwood Brake Kit. Includes calipers, stainless lines and carriers that allow you to use a stock E36 rotor.
    Here is a link to the original listing: http://www.offcamberautosport.com/cu...brake-kit.html
    Will include a set of used PFC08 pads.
    Sells for $900 new. Asking $450.00 shipped in the continental US
    Sep 2008
    SWFLA
    ‘97 E36 'vert, ‘08 E93
    If they fit stock M3 rotors, will they also fit with factory 17’’ contours? It would seem that way, can you confirm?
    Apr 2014
    Slidell, LA
    Many
    They should fit any stock configuration as they work on stock rotors. I never ran them with stock rims though. If you want to know for sure, I would reach out to Off Camber directly.
    Jan 2005
    Huntsville AL
    1997 M3
    Does this offer a noticeable weight savings over the factory caliper?
    Apr 2014
    Slidell, LA
    Many
    Honestly, you won't notice the weight difference from behind the wheel, but they are significantly lighter than stock calipers. These are aluminum vice cast iron.
    Jan 2005
    Huntsville AL
    1997 M3
    Quote Originally Posted by darbyfam View Post
    I'm in that drop whatever weight a can to try and claw back against the light cars in my class mode. Its autocross so i'm not worried about most of the attributes other than weight. Every little bit helps, especially unsprung. 5-10lbs a corner is useful weight in the grand scheme. Id assume its lighter I was just hoping you may have numbers.
    LV, Pa
    944 Turbo
    In my experience, even with steel brackets the weight savings is never less than 5 lbs per corner with wilwood 4 piston vs stock e36 m3
    Apr 2014
    Slidell, LA
    Many
    Quote Originally Posted by snakebit8 View Post
    Google tells me the stock M3 front caliper/carrier weighs ~10.5bs each and the Wilwood site says these calipers weigh 5.2lbs each.
    Apr 2014
    Slidell, LA
    Many
    Sold
  1. UUC * Blemished finish Wilwood brake kits - blowout pricing. See inside for details.
    By Rob Levinson in forum Group Purchases & Supporting Vendor Specials presented by eBay
    Last Post: 11-16-2009, 03:37 PM
  2. UUC * Special for week of 6/11/07 thru 6/16/07 * Wilwood brake kits - special offer
    Last Post: 06-11-2007, 11:49 AM
  3. Wilwood Brake Kits for Track / Race Car?
    By bimmerfish in forum Track, Auto-X & Drag Racing sponsored by Bimmerparts.com
    Last Post: 03-30-2007, 09:54 PM
  4. Wilwood Brake kit
    By trimegatron in forum 1992 - 1999 M3 (E36)
    Last Post: 03-26-2007, 10:16 PM
  5. UUC/Wilwood Brake Kit
    By Mvez in forum 2001 - 2006 M3 (E46)
    Last Post: 12-27-2006, 10:43 PM
