SOLD
SOLD
SOLD
Used OffCamber Wilwood Brake Kit. Includes calipers, stainless lines and carriers that allow you to use a stock E36 rotor.
Here is a link to the original listing: http://www.offcamberautosport.com/cu...brake-kit.html
Will include a set of used PFC08 pads.
Sells for $900 new. Asking $450.00 shipped in the continental US
If they fit stock M3 rotors, will they also fit with factory 17’’ contours? It would seem that way, can you confirm?
They should fit any stock configuration as they work on stock rotors. I never ran them with stock rims though. If you want to know for sure, I would reach out to Off Camber directly.
Does this offer a noticeable weight savings over the factory caliper?
Honestly, you won't notice the weight difference from behind the wheel, but they are significantly lighter than stock calipers. These are aluminum vice cast iron.
I'm in that drop whatever weight a can to try and claw back against the light cars in my class mode. Its autocross so i'm not worried about most of the attributes other than weight. Every little bit helps, especially unsprung. 5-10lbs a corner is useful weight in the grand scheme. Id assume its lighter I was just hoping you may have numbers.
In my experience, even with steel brackets the weight savings is never less than 5 lbs per corner with wilwood 4 piston vs stock e36 m3
Sold
