Doing an engine swap in my Z3 using a donor M-Roadster - going from the M44 to S52. I'm curious if anyone has done this, and if the chassis harnesses are significantly different when it comes to key components, such as the ABS/ASC. A few key items after pulling the engine has me a little concerned I may have to pull over the chassis harness as well. Interested if anyone has experience with this - particularly the below questions.
- Does the fuel system need to be swapped as well - pump and sender, fiter and regulator?
- If the speedo is coming over from the M, assume the control box will as well - are the chassis harnesses going to work together with the M speedo/tach senders?
- If ABS and other components all work off the same sensors, is there any impact to just using the M roaderster ABS control box?
I have all of the M parts/harnesses but they're a real PIA to get out and I'd rather not have to completely remove the recipient car's harness and reinstall for a few minor differences that I may be able to just wire separately. ETK suggests there are some slight differences in the ABS but its hard to tell if switching over the relays and control boxes might solve this. The recipient chassis is pretty well gutted for track setup, so getting to the harness isn't so bad, but removing the center section to get behind the AC/Heating system is going to be a real pain.
Its been done a few times, M44 to S52 swaps, have you searched for those?
I cant inagine youll have to swap the chassis harness. Fuel pump yes, 4 cyl pump wont supply enough for the s52.
Gauge cluster, dme, yes, swap those
You could use realeom to see what parts, sensors and harnesses are shared with what
PRICE CUT on ALL FABRICS
-Abel
- 2000 Z3: Many Mods.
- 1999 S52 Estoril M Coupe
- 2016 Mini Cooper S
