RM European Auto Parts
Results 1 to 2 of 2
Thread: E46 V10 S85 SMG (E60 Powertrain)
    May 2019
    Jakarta
    BMW 1M E82 V8 S65
    Hello everybody,
    with an E46 V10 S85 (Hartge conversion) I have the following problem:
    The battery discharges consistently by a much too high quiescent current, as some controllers do not fall asleep. Quiescent current I measured with a multimeter after about 12 hours in the closed state. Value is around 770mA.
    After I have sent the PowerDown command via ISTA, the quiescent current has slipped to the desired value after about 12 hours (0.03 - 0.04A) which roughly corresponds to 35mA.
    After this process I measure since then after 12 hours completed quiescent currents around the 120 - 180mA.
    Since then PowerDown command started the engine sometimes.
    The fact is that no IBS is installed and the electrical system is not monitored.
    Furthermore, the following ECUs are installed in the vehicle: E60 (DME, SMG, DSC, SZL, KGM, CAS, COMBI, BZM)
    The vehicle is completed normally via the remote control key.
    Now my questions:
    Does the IBS have to be installed so that all E60 control units fall into deep sleep?
    Is it possible to simulate the PowerDown command or trigger it during the closing process?
    When do all controllers fall into deep sleep?
    This situation was solved unsightly by a KillSwitch in the trunk, which is definitely not worthy of the vehicle.
    Thank you in advance!
    MauiM3Mania's Avatar
    Jan 2002
    Central Pacific
    88M3 99M3 04M3 ITBx16
    Any experts out there?
    88M3 AW 43k miles Project FS
  1. E46 m3 v10 s85
    By TEUTONIC in forum BMW Rides & Events
    Last Post: 01-30-2014, 05:21 PM
  2. E46 E46 M3 Alcantera SMG Boot
    By e30shmobberr in forum Interior Lighting & Body Parts
    Last Post: 10-24-2011, 02:17 PM
  3. E46 WTB E46 M3 Convertible SMG - Lower miles the better
    By Un0RiGiNaL in forum 3 series & Z Series
    Last Post: 04-07-2011, 12:22 PM
  4. E46 FS: UUC LW Flywheel & clutch - 03+ E46 330 6spd/SMG, Z4 3.0, 04+ 530i
    By Frostvr4 in forum Drivetrain & Transmission Parts
    Last Post: 10-15-2010, 07:44 PM
  5. E46 WTB: E46 M3 Coupe SMG 2002-2005 LSB/PY (SoCal)
    By Gatsbi in forum 3 series & Z Series
    Last Post: 07-30-2010, 06:38 AM
