Results 1 to 5 of 5
Thread: Can I put replacement speakers in 2002 530i?
    May 2019
    lincoln,ne
    2002 bmw 530i
    Not sure which system I have I replaced the head unit. How do I know if i have harman kardon speakers? Can I put after market speakers? I want to replace all if possible?
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    moved to E39 general forum from E39 DIY
    Apr 2018
    Socal
    00 528i, 01 540i
    I don't think harman kardon was an option in the e39. But you sure can replace all your speakers with aftermarket ones. They use 5.25" speakers and tweeters.
    Sep 2008
    West London/Heathrow - UK
    03 530dT - Ex Police Car
    Hi,
    The above from atobe is actually incorrect. The OEM BMW system(s) assuming that's what you have in your car are 'closed' type setups, i.e bespoke to the car's design from factory. They use a different impedance and also anywhere there's an enclosure (the front doors in the E39's case) they're optimized for the OEM speaker characteristics. After market speakers use the convention of 4 ohms so if you connect a speaker with that impedance to the OEM BMW setup, you will get 'sound' but it won't be 'right' as it were.
    The only direct fit, impedance matched/friendly speakers that make the 'best' of the OEM setup and are designed with the OEM characteristics in mind, are the BSW/Bavsound ones - https://www.bavsound.com/
    Harman Kardon wasn't an option in the E39.
    Cheers, Dennis!
    Oct 2018
    Roseburg, Oregon
    2001 BMW 530i Touring
    I tried replacing the door speakers in my wagon with aftermarket units. The results were way worse than the original speakers. Eventually I sprung for the Bavsound kit, and it is much better than OE.
  1. Oil pan gasket replacement for Dummies - 2002 530i
    By texasbmw530i in forum 1996 - 2003 (E39)
    Last Post: 11-21-2019, 08:12 AM
  2. Oil pan gasket replacement 2002 530i 105k miles
    Last Post: 03-24-2014, 11:50 AM
  3. 2002 530i Radiator Replacement
    By roy1170 in forum 1996 - 2003 (E39)
    Last Post: 06-19-2010, 05:52 PM
  4. how to replace low beam bulb. HELP 2002 530I
    By nickjr in forum 1996 - 2003 (E39)
    Last Post: 02-07-2009, 05:36 PM
  5. 2002 530i clutch replacement - Help needed
    By C Minus in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 11-30-2005, 06:44 PM
