Results 1 to 5 of 5
Thread: Steering wheel wobble when braking at higher speeds..
    Oct 2014
    Ottawa, Canada
    2001 BMW 740il
    I’ve been having steering wheel wobble when being a little hard on the brakes at higher speeds for a while now and some pulling to the right and left. It’s not necessarily a perfect straight line feel when going hard on the brakes. Changed the pads and rotors two summers ago. Wheels are balanced. Front tires are like new still. There is slight play in the front control arms I am told by an indy and the dealer. My question is can the control arms be that much of a problem? Or something else?
    Brought it to a performance shop for other work today (stainless steel stop tech front brake lines and bronze bushing guides) It’s unrelated to the issue since it’s been on going beforehand. Just thought i’d throw that out there. Barely noticed a difference in the brake pedal firmness. I was hoping for a noticeable difference in the pedal feel. Maybe it’s masked from the steering wobble.
    Jan 2006
    Las Vegas
    00 E38,01 E38,99 323 is
    Your issue can be caused by bad bushings in the front suspension. But also by rotor issues. You need to determine which of those is more likely. Being only under braking, more likely the rotors. You need something to check runout (I think that is the term) basically checking that the rotor is straight all the way around and the dial indicator doesn't change values as the rotor is turned.
    9/2004 Chevrolet Suburban Z71, black, purchased March 2016, 270k miles.
    6/99 740i Cosmos Schwartz M Sport, 214k miles, purchased May 2017
    2001 740i OrientBlau M Sport, purchased March 2023
    1984 MasterCraft Stars and Stripes, Blue/White, PCM Ford 351W, PowerSlot, 912 hours, purchased September 2012 (not a car )
    4/99 323is/5. Titansilber, 211k miles. Straight body project.
    past BMWs: 5/1994 325isa (Arktisgrau), 3/1997 328is/5 (cosmosschwartz), 9/1990 535i/5 (calypsorot), 9/1990 318i/5 (brillantrot) 7/93 325i/5 convertible (samoablau) 2/92 325i/5 cabriolet (lagunengruen).
    SÜNDE REISEN
    Oct 2014
    Ottawa, Canada
    2001 BMW 740il
    If the rotors check out that they are okay what would be the problem then? I have brand new coil overs installed two summers ago so i don’t think it would be suspension related.
    Feb 2010
    Hampshire UK
    99 840ci Sport Indv
    My BMW Repair YouTube Channel
    Dec 2011
    Lancaster CA
    e34,e38,e39,e46,e70,e90
    Did not read Timm's piece, but had this on three different vehicles, including a Suburban, each time it was the brake rotors.
  1. Steering wheel tug when braking at low speeds
    By Traian in forum 2006 - 2012 (E90, E91, E92, E93)
    Last Post: 08-27-2016, 01:28 AM
  2. Steering wheel shakes when braking at high speeds? HELP E38 Gurus!
    By alpinewhite740i in forum 1995 - 2001 (E38)
    Last Post: 04-26-2015, 09:16 PM
  3. Steering wheel wobble while braking @ 40
    By DANGARD in forum 1988 - 1994 (E32)
    Last Post: 10-16-2010, 02:09 AM
  4. wheel wobble when braking at high speed please help!!!
    By e361995320 in forum 1991 - 1999 (E36)
    Last Post: 08-16-2008, 12:54 PM
  5. when braking at higher speeds my steering wheel shakes
    By nds19677p in forum 1982 - 1988 (E28)
    Last Post: 06-28-2007, 11:12 PM
