Strange thing started on the E21. For a couple of days the blinkers blinked really fast on the right side. I thought it was a bulb. A few days later the blinkers completely stopped on either side - no regular or fast blink, no arrow on the dash. The Hazard switch when activated stays lit solid red...no blinking.
I have checked the fuses at 16B but all look good. Any thoughts and ideas would be appreciated.
1981 BMW 320i, Ascot Grey with Tan Leatherette, 137K, 5 speed, K&N filter, Ansa Exhaust, Bilstein HD's, Rota RB's, Bumper Tuck.
2013 BMW 535i M Sport, Arctic Silver with Black interior.
1966 Ford Mustang Convertible 289 cc, 56K, Dark Grey on Black, Styled steel wheels, C4 Automatic.
1014 Porsche Cayman S, Black on Black
The relay is good?
Sent from my SM-G930V using Tapatalk
e30 325i, the mighty 4 door granma mobile....Gone
e39 528i, 4 door sports tank
Sounds like you have a faulty hazard switch which controls your turn signals and your windshield wipers as well as the light on your digital clock, you’ll be needing a new hazard switch or are you will need to do a hazard switch bypass so you could have working blinkers and you will also notice your windshield wipers will not work until it’s fixed
I traded out the hazard switch and the same problem exists, no blinkers and the hazard switch stays lit solid red. Have not checked the relay. Is there an easy way to check the relay? Thanks for the help
For me, it was the wiring to the relay. If at all possible find a relay to test
