Results 1 to 5 of 5
Thread: Brake Bleeders
    Dec 2007
    Los Angeles
    99 328iS
    Brake Bleeders
    I am looking to buy a brake bleeder. Thoughts on vacuum vs pressure?
    https://www.amazon.com/Capri-Tools-V...-1-spons&psc=1
    https://www.amazon.com/Motive-Produc...gateway&sr=8-6
    Jun 2016
    North Carolina
    03 525it/5, 1967 GTO
    I’ve had the motive for a long time now. I modified the pressure hose to incorporate inline valves/quick connects so I can disconnect the cap to add fluid without losing pressure plus swap between different caps for non euro cars. I only use it for pressure and don’t add any fluid to the motive tank itself for pressure/gravity style bleeding. Works a treat.
    Mar 2018
    Tempe AZ
    1996 BMW 328is
    I recently bought the motive pressure bleeder and it works wonders. Turns a brake bleed / clutch bleed job into a one man job. highly recommend it.
    Wisconsin
    98 328IS 03 325xi
    I've got a pressure bleeder that I bought from Bav Auto. I came with a quick disconnect on the cap to make things easier to connect and the cap supposedly fits most European cars. Makes bleeding/flushing a one man job.
    Gave away my BMWs, driving a VW and an Audi now.
    Jan 2002
    outta SoCal, now CO
    '98 M3 Alpine White
    Both work. The issue that I always had with the vacuum type is they draw air in around the threading of the bleeder. Not a system issue but it makes it appear that there's lots of air coming out of the lines. Personally, I like to see an accurate visual of how much air is passing through and the vacuum type won't let you do that. Go pressure. Vacuum type is good for draining the reservoir, but my turkey baster with a ball bearing in it work just fine.
    See ya later,
    tony
    '98 M3, '92 Dinan3, '05 R1100S BCR, '07 R1200S, Aprilia T
  1. brake bleeder stripped
    By dachronic in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 08-25-2003, 03:06 PM
  2. Building a Pressure Brake Bleeder
    By M3 Pete in forum 1992 - 1999 M3 (E36)
    Last Post: 03-27-2003, 04:27 PM
  3. Brake Bleeder anyone?
    By sardil in forum Middle Atlantic - US
    Last Post: 02-24-2003, 12:46 PM
  4. brake bleeders....
    By NY98M3 in forum 1992 - 1999 M3 (E36)
    Last Post: 02-18-2003, 12:42 AM
  5. Brake Bleeders
    By MojoMoto in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 09-19-2002, 03:31 PM
