Results 1 to 7 of 7
Thread: Magnetic drain plug
    May 2019
    MCKENNEY Virginia
    1997 Z3 Roadster
    Magnetic drain plug
    I would like to put a magnetic drain plug in my transmission a 97 z3 Roadster with a 6 cylinder 2.8 anyone know what size and thread the drain plug is not had any luck so far.
    Jun 2010
    NY
    1997 328i
    Below is a magnetic plug, but I would suggest to just add a small neodymium magnet to your current plug. Just look up the dimensions of your current plug or a picture to get an idea of what shape and size will work, get a neodymium magnet off ebay. Just don't get a huge magnet, the trans pan has solenoids that it may interfere with, as long as it's small similar to the one at ECS it should be fine.
    https://www.turnermotorsport.com/p-3...g-priced-each/
    May 2019
    MCKENNEY Virginia
    1997 Z3 Roadster
    Quote Originally Posted by Eric93se View Post
    I am afraid that the magnetic part would fall off
    Jun 2010
    NY
    1997 328i
    You could put a very small dab of RTV silicone to help hold it. Also the magnet is very strong and your sticking it to steel. It's not going anywhere.
    I once put a cylindrical magnet on my engine oil drain plug, it was pretty long like almost an inch. I epoxied it to the plug, it lasted a long time but the epoxy didn't like being in the oil, a different epoxy may have worked better.
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    There is actually no need to put a magnet on the drain plug of the trans, there are magnets in the trans pan originally installed , for example ZF 1043 301 036 Magnet, in the 5HP18 2 of them.
    I always clean them when I change the filter, these magnets are also good to see the condition of your trans . Here you can see them when we make a trans service on a ALPINA E36 B6 ZF 5HP19, Valve Body Repair http://e32b12.blogspot.com/2013/10/a...dy-repair.html
    or do you talk about a mechanical transmission?
    Wisconsin
    98 328IS 03 325xi
    If you have the zf manual trans the drain and fill plugs are M24X1,5.
    Gave away my BMWs, driving a VW and an Audi now.
    Jun 2010
    NY
    1997 328i
    Not everyone wants to drop the pan when doing a service. So having a decent magnet would grab some material.
  1. are magnetic drain plugs a good idea?
    By kevinsky18 in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 02-01-2007, 06:55 AM
  2. Replies: 3
    Last Post: 01-23-2007, 08:39 PM
  3. UUC * FREE MAGNETIC DRAIN PLUG - this weekend only!
    By Rob Levinson in forum Group Purchases & Supporting Vendor Specials presented by eBay
    Last Post: 01-14-2007, 11:54 PM
  4. Magnetic Drain Plug
    By Kdog2112 in forum 1996 - 2003 (E39)
    Last Post: 07-10-2006, 02:11 AM
  5. Magnetic Drain Plug Highly Recommended
    By Scimitar in forum 1991 - 1999 (E36)
    Last Post: 07-08-2003, 04:38 PM
