Results 1 to 6 of 6
Thread: Are there any members running this product?
    Oct 2018
    indianapolis
    1995 318i convt.
    Been reading into this the last couple of days. Wanted to see if anyone is running them and if so how well they worked and how much gains if at all IMG_1088.jpgwere had from it.
    Jun 2016
    California
    E36 325is
    Looks like a very nice part. ITB's are usually not plug and play, but if I had the cash I would run that. I think the main thing would be the tune, you will need either a programmable chip, (There are like two) a piggy back or a stand alone ecu.
    I would say go for it, don't be turned off by the price either... Carbon fiber is a bitch to work with and that looks damn hot.
    Nov 2013
    Oneida, NY
    1993 318is/who to knows
    Agreed, if i had the cash for that and the tune, id do it. I pretty much made one of those once, but i couldnt get them all synced perfectly as the adjustments had to be modified onto the tb exactly the same. Better off buying than trying to replicate.
    -Oakdizzle
    Feb 2008
    Durango/Bayfield CO
    1995 M3 Coupe 5pd
    You'd need an ecu unless the plenum is configured for a MAF. For early cars it's not too hard to go with Megasquirt ECUs but as with later models, you have to figure in the vanos, then becomes more complicated especially when trying to integrate other systems on the main harness.
    Checked out this system and it does use the factory MAF. So got to find someone to build a tune for it.
    I did this for my other car.
    Tom
    Currently 1995 M3 manual coupe, 1993 325is
    Past cars
    2003 530i
    1998 528i
    1995 530i
    1988 528e
    1988 535i
    1987 2.7i
    1972 2002
    Jun 2005
    New England
    F90 M5; E36 M3 Turbo
    Would be curious to see a before and after dyno test.
    Feb 2008
    Durango/Bayfield CO
    1995 M3 Coupe 5pd
    I think it will run fine, but without bumping compression and big cams, probably won't be too much more.
    Tom
    Past cars
    2003 530i
    1998 528i
    1995 530i
    1988 528e
    1988 535i
    1987 2.7i
    1972 2002
  1. Any members running without the mechanical fan?
    By 2rbolag in forum 1996 - 2003 (E39)
    Last Post: 11-12-2014, 11:28 PM
  2. Any 1 running Pzero Rossos? Comments?
    By acsm3 in forum Tire & Wheel Forum sponsored by The Tire Rack
    Last Post: 03-24-2009, 06:44 PM
  3. Any Members In S. Jersey?
    By Az1aN in forum 1992 - 1999 M3 (E36)
    Last Post: 11-08-2002, 03:00 PM
  4. is there any disadvantage to early production 95 M3
    By SDKCM3 in forum 1992 - 1999 M3 (E36)
    Last Post: 01-21-2002, 09:16 AM
  5. Any 1 running Pzero Rossos? Comments?
    By acsm3 in forum 1996 - 2003 (E39)
    Last Post: 08-29-2001, 08:32 PM
