Results 1 to 9 of 9
Thread: Help with E36 M3 suspension choices
    Aug 2012
    seattle, WA
    1978 euro 635csi
    This car is my daily driver for work commuting. No racing, no tracking, just fun city driving with short sections on the freeway. The roads here are very poor. I had an e36 328is with sport suspension, and that was perfect. My son wanted the e36 328is and i had an e36 m3 20 years ago and loved it, so i sold my son the 328is and bought an e36 M3.
    The e36 was slammed when i got it, I had the springs replaced with H&R, they were supposed to be close to stock, but the ride is still too stiff and violent on these really poor streets. So before i go find myself another e36 328 sport, i just wanted to check, are there any "softer" suspension packages that would make my e36 M3 ride like my 328i sport?
    I've looked and searched a bit, but everyone seems to want to go the other way (lower / stiffer). I realize there may not be a solution, other than getting a 328i sport. I like the sharp looks of the m3 body additions and the better trans, which is why i'd like to find a solution for the M3.
    Thanks in advance.
    Oct 2003
    Seattle
    99 M3
    H&R OE Sport Spring are a pretty good compromise when paired w/Koni Sport Shocks. Very modest lowering, OE (or softer) ride comfort.
    328 and M3 were fit w/same ZF S5D 320Z 5-speed transmission.
    https://en.m.wikipedia.org/wiki/ZF_S5-31_transmission
    Aug 2012
    seattle, WA
    1978 euro 635csi
    Quote Originally Posted by bluptgm3 View Post
    H&R OE Sport Spring are what i had put on there. If i push down on the fender by the headlight with one hand, it can barely make the car move. Maybe 1cm. If i push down on the 328i sport with one hand on the fender by the headlight, it moves easier and moves about 1.5 inches. That give, that the 328i sport has, goes over all the potholes and washboard very smoothly in my area. Is it possibly the sway bar difference? Is the sway bar adjustable?
    Talking automatics:
    ZF 5HP18 vs GM 4L30-E
    5 speed auto vs 4 speed auto
    And before we get into the "manual" vs. "auto": I was hit by a car on my motorcycle and have had reconstructive surgery on my left knee twice now. I do prefer a stick when driving for fun, but for my daily commute in the stop and go, my knee says "auto please".
    Oct 2003
    Seattle
    99 M3
    It is possible the ‘jounce’ test is being resisted by shock/strut dampening, M3 vs 328.
    Dec 2012
    los angeles,ca
    1999 m3 coupe
    have you looked at fat cat motorsports ?
    Peoria, AZ
    03 zhp, 97 e36m3, 04 zhp
    Sounds like you are prime candidate for refreshed OEM stuff, stock springs with stock dampers.
    Portugal
    '95 E36
    Quote Originally Posted by Mless5 View Post
    ^This. OEM M3 suspension should be similar to the 328i sport one.
    '95 E36 318tdS:
    Bilstein Sport shocks; x-brace; H&R front sway bar; camber shims; M3 offset LCABs; Meyle HD LCAs; Z3 RSM reinforcement plates; ZHP shift knob.
    Oct 2003
    Seattle
    99 M3
    You could probably run H&R OE Sports with OEM Sachs Struts and Shocks.
    Sep 2008
    bay area
    95 m3
    In the same boat. anyone have opinions on kw v1 or st coilovers. found a deal on a site for basically half off.$500 if its good maybe op can benifit from this too?
  1. Help with E36 M3 suspension overhaul
    By ColdshotM3 in forum Suspension Tech and Handling sponsored by eBMWParts.com
    Last Post: 03-12-2013, 02:40 PM
  2. Help with E36 M3 suspension overhaul
    By ColdshotM3 in forum 1992 - 1999 M3 (E36)
    Last Post: 03-10-2013, 09:08 PM
  3. E36 M3 Suspension Help
    By arctikpenguin in forum Suspension Tech and Handling sponsored by eBMWParts.com
    Last Post: 02-11-2010, 09:22 AM
  4. help e36 m3 suspension on 325is
    By coolx7 in forum Suspension Tech and Handling sponsored by eBMWParts.com
    Last Post: 12-27-2009, 12:09 AM
  5. E36 M3 suspension ideas/help.
    By sa24 in forum 1991 - 1999 (E36)
    Last Post: 07-31-2009, 10:10 PM
