I bought a 325e last summer, and it came without a fan shroud. Since I'm in TX, I decided I'd put one back on.
I bought the correct shroud according to realoem.com, and was trying to install it as a final piece of replacing the water pump and timing belt. When mounting the shroud on the radiator. the center of the opening in the shroud looks to be offset an inch or so to left when looking from the front of the car relative to the center of the fan, and there's no clearance between the right side of the fan and the opening in the shroud. The radiator is sitting correctly in the rubber mounts, the radiator mounting bolts are in the correct holes in the radiator support and the tabs on the bottom of the shroud are in the slots at the bottom of the radiator.
Has anyone else had this issue and if so, how did you resolve it?
Thank you in advance for sharing your experience.
check your motor and transmission mounts. it should sit in it properly
No e30s again.
Hopefully the car was not involved in a front collision
I would not expect left/right alignment issues that severe with bad motor mounts. I would expect up/down issues. Take a good look at both frame rails. Compare with a "known good" E30 if you don't see anything obvious. Something is bent somewhere.
9/2004 Chevrolet Suburban Z71, black, purchased March 2016, 270k miles.
6/99 740i Cosmos Schwartz M Sport, 214k miles, purchased May 2017
2001 740i OrientBlau M Sport, purchased March 2023
1984 MasterCraft Stars and Stripes, Blue/White, PCM Ford 351W, PowerSlot, 912 hours, purchased September 2012 (not a car )
4/99 323is/5. Titansilber, 211k miles. Straight body project.
past BMWs: 5/1994 325isa (Arktisgrau), 3/1997 328is/5 (cosmosschwartz), 9/1990 535i/5 (calypsorot), 9/1990 318i/5 (brillantrot) 7/93 325i/5 convertible (samoablau) 2/92 325i/5 cabriolet (lagunengruen).
SÜNDE REISEN
Or you could have an aftermarket radiator that didn’t have the fan shroud mounting points put in the right location
This is very likely, i have an INA radiator and it is just 1-2 mm off on the shroud mounting points. When i laid the old radiator (origina 30 year old BMW one) on top of the new one, everything lines up (to the naked eye). Only when i mounted the shroud i noticed it was just that smidge off, just enough to make one notice but not enough to cause any issues, some slight hand pressure was enough to get spot on alignment.
Or maybe the plastic parts on the old radiator have expanded and contracted so many times over the years, the alignment slightly changed when compared to a brand new one?
Or were there different sized shrouds available?
Perhaps you were shipped the wrong shroud.
That’s an even more logical explanation
