Results 1 to 7 of 7
Thread: car startup suspicion
    west new york,nj
    328i
    A few days ago, I realize the starting get a bit rough. The starting took longer time and there was some shaking as well. I looked up the forum and did the following:
    1. no misfire error in the ECU
    2. cleaned MAF
    3. There is recurring P1421 code and I found the small hose linked to the 2nd air pump valve is broken and the valve has some rust color. So I replaced the valve and hose. I replaced the 2nd air pump a year ago and there is no rust/noise/dampness in the pump.
    The car is not shaking so far while the prolonged startup still remains. Do I need to replace something now to avoid sudden failure? Is it starter?
    Jun 2010
    NY
    1997 328i
    Smoke test it to find all the vacuum leaks. Start running injector cleaner over the next 3 tanks of gas. Your injectors could be leaking down.
    You CAM sensor could be on its way out. Use an old laptop and put INPA on it and get the cable off ebay.
    https://www.bimmerforums.com/forum/s...ad.php?2184573
    west new york,nj
    328i
    Today the only error p1421 shows up again. The 2nd air pump has no apparent noise. Is it the problem?
    Jun 2010
    NY
    1997 328i
    The SAP only comes on during cold weather so I don't know why that code shows during warm weather, you cleared the code and it came back?
    Did you replace the valve that is on the exhaust manifold? You can test that the valve is not leaking by disconnecting the large hose from the SAP and blow in to the hose in the direction of the engine, no air should flow.
    west new york,nj
    328i
    Last time I didn't but this time I did. I use the glove to test if there is air leaking while engine is running as shown on YouTube. I don't feel obvious airflow.
    What's cam sensor? Where should I look after hooking up laptop? The start seems more struggling now.
    west new york,nj
    328i
    ok, cam = camshaft sensor. I can associate the loss of power during drive with camshaft sensor issue. On youtube, there is a way to verify if camshaft sensor is good by measuring the voltage during metal contact. Given camshaft sensor is easy to access, is it better than hooking up computer?
    The 2nd air pump code comes back all the time.
    Quote Originally Posted by Eric93se View Post
    west new york,nj
    328i
    Finally get error code P0340. Ordering camshaft sensor to get over it.
  1. Aux fan runs at startup when car is cold...
    By HarvesterOfBeer in forum 1992 - 1999 M3 (E36)
    Last Post: 06-09-2006, 05:28 PM
  2. Car revs up to 3000 rpm at startup
    By 65Matt in forum 1991 - 1999 (E36)
    Last Post: 11-24-2005, 11:33 AM
  3. Car stalls during startup on hot days
    By GPappas in forum 1991 - 1999 (E36)
    Last Post: 08-27-2004, 08:28 AM
  4. HELP car revs by itself on startup
    By BiMmEr JoN in forum 1991 - 1999 (E36)
    Last Post: 09-17-2003, 07:20 AM
