Results 1 to 14 of 14
Thread: E46 325Ti Rear Wiper doesn't spray water
    May 2019
    Germany
    2007 Toyota, 2002 BMW
    Hi to everybody, I got a 2002 E46 325Ti, and I'm having the issue described in the thread's title, I can't get no water sprayed from the rear wiper. Has anyone diagrams about the whole system, or maybe anyone knows of a very frequent cause to check first?
    THX!
    Jan 2016
    Ca
    2001 525it
    Mine does not work either I know the washer motor is up front in the bottle and the hose disappears as it goes back that's all I know, I thought about fixing it but.....
    Mar 2019
    ATLANTA GA
    456 X3s
    nice little car, I have the 05 e83...but here's what we did (and went through) to get to the solution...
    https://www.bimmerfest.com/forums/sh...php?p=12784097
    start at #204
    ends at #280 I think...we stop and detour a couple of times from rear sprayer problem...turned out to be a hose disconnect underneath the carpet passenger side rear...I was a man posessed!
    Sent from my SM-J727T using Tapatalk
    Aug 2009
    Silver Spring, MD
    03M3 17M540 18A5SB
    LOL...the wet carpet must have been the wakeup call!
    Quote Originally Posted by X3456 View Post
    start at #204
    I had a problem with audi S6 wagon rear washer...pump was fubar. Getting the new one in pissed me off because the new one (audi oem!) had a smaller OD into the washer bottle and I had to go to the stealer again to get the right size grommet. Gotta love backward-compatible parts...the new part should have had the grommet with the pump.
    May 2019
    Germany
    Thank you all for your feedbacks.
    The problem is, my car has a dedicated water reservoir alongside right C-Pillar, so I don't think there is any line at all connecting the water pump on the back to the main reservoir located inside the Bonnet (Bonnet= motor cover or Motorhaube)
    Does anyone here has a TI (AKA Compact) and met the same problem?
    Mar 2019
    ATLANTA GA
    456 X3s
    So where have you detected the leak?
    dworthy's Avatar
    dworthy is online now Wagon meister :) BMW Tech Expert
    Nov 2010
    Grafenwoehr, Germany
    16 220i 05 325it 05 M3
    Quote Originally Posted by AEnrico View Post
    THX!
    Welcome to the wagon Fun!
    Yes the typical problem is the wiring in the hatch. So if you open the hatch, on the right side near the hinge you will see a black rubber "Y" hose. That is where the cable for the wiper/wash system goes, and from the open/closing of the hatch, it will weaken the wire. What you can do is open the right rear compartment, where the battery is, and unhook the connector to the washer pump. Using a test lamp, and the hatch will need to be closed for this, push forward on the stalk. If the lamp doesn't come on, you would need to trace the wire to the breakage. It the light does come on, the you will need to replace the pump.
    Where bout's in Germany are you? P.M. me if you like.
    Darin
    Current:
    Past:
    79 525 euro Green/Green RIP
    M-Flight Member
    May 2019
    Germany
    Hi, I'm in Bayern, but my German is very poor! I checked today the water pump, at least it runs. Maybe it's just clogged, I should still check it. I saw some little rusty drops coming out of the nozzle, I'm more and more convinced it's a coggled and long time neglected water line causing the problem.
    Mar 2019
    ATLANTA GA
    456 X3s
    Is the car new to you...do you know its history? it's not advisable to use a probe of any sort. finally have you found leakage?
    May 2019
    Germany
    Yes, and it's my first ever BMW. Well, it's meant to be more of a toy! No leaks discovered so far, but I didn't disassemble the trunk lining, just visually checked water reservoir and trunk's bottom looking for water strains or moisture.
    dworthy's Avatar
    Nov 2010
    You can jump the pump as the battery is right there. I it should be the Black/Red wire: https://www.newtis.info/tisv2/a/en/e...r-pump/eqUbMDo
    If you are from the Graf area, I will be in the Skills Center on Sunday 26 May from 0900-1600, ask for Darin the BMW guy.
    Darin
    Current:
    Past:
    M-Flight Member
    May 2019
    Germany
    The pump is working, or at least it's trying to do it. I can hear it spinning. I just downloaded and installed BMW's TIS, I looked at the instructions to replace the back washer, at the first available moment I will get rid of the trunk's lining, disconnect the water line and see if it will spill water when running, or if the water line is just broken. The main time's consuming task should be removing the lining to expose water tank and water line, I think.
    dworthy's Avatar
    Nov 2010
    Something else came to mind with those pumps, they have a metal shaft connected to a plastic impeller. If the water gets frozen due to the lack of correct washer fluid, it can break the shaft loose from the impeller. So while it can sound like it is working, but it's not.
    Darin
    Current:
    Past:
    M-Flight Member
    May 2019
    Germany
    Solved! Nozzles were clogged!
  1. rear wiper doesn't work...
    By JT///M3 in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 08-24-2011, 01:32 PM
  2. E46 Touring - troubleshooting a malfunctioning rear wiper
    By billschusteriv in forum 1999 - 2006 (E46)
    Last Post: 02-24-2011, 02:05 PM
  3. Coupe rear wiper doesn't work...
    By jbt56 in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 11-13-2007, 09:51 AM
  4. E46 compact rear wiper assembly parts problem
    By al89 in forum 1999 - 2006 (E46)
    Last Post: 08-20-2007, 10:48 AM
  5. E46 rear wiper - help w/motor replacement?
    By bird67 in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 04-09-2007, 05:49 AM
