Results 1 to 13 of 13
Thread: AC help
    Feb 2019
    el paso
    1985 BMW 325e
    AC help
    My 1985 BMW 325e it has the AC update it to R134. The issue is that once the vehicle is stop the AC stops giving cold air. I only get cold air when I am in the Highway. Any guess what could be the issue?
    Dec 2012
    Grandview, MO
    1989 Bmw325IC
    It could be low on R134A. Then again my 89 325i has been converted to R134a and it does not cool well at low RPM. On the highway it is good. R134A is not as good as R12 especially in a system designed for R12. Check to see if you are low first.
    May 2010
    Officially in Tampa
    87 Cabrio & 87 ETA
    Jumping the resistor on the aux fan will help cooling at idle. Just remember to boost the low speed fan fuse.
    87 Zinno Cabrio 98k Barn Find. Build thread http://www.r3vlimited.com/board/showthread.php?t=268987
    87 Lachsilber ETA Time Capsule. bought w 125k from 87yo original owner
    Cabrio deck lid & hinge struts (w sleeves) now for sale. See the link below for more info
    New "made in Europe" seat shocks. PM for details
    http://www.bimmerforums.com/forum/sh...ot-Seat-Shocks
    Feb 2019
    el paso
    1985 BMW 325e
    I will check the pressure first. I saw that Pep-boys do free AC checks
    Dec 2005
    corpus christi, texas
    No e30s, again :(
    I second checking the fan. sounds like something is wrong. my first e30 was an 85 325e and I converted it to 134 and it was very nice.
    also, if you get tired of the 134 and its cooling, evacuate the system and convert to r290 (common name: propane). its way cooler and doesn't leak out of the lines so easy because the molecules are larger. it works especially well in the older r12 systems because its very similar to r12, size wise. I use it and have for over a year now. my son's e30 is running it and his vent temps are 42-45 degrees in the summer. once I get tires on my truck, the ac is the next thing to fix. it will get filled with r290, also
    google it because a ton of uneducated people will come on and say you will catch fire and blow your car up but its already a commonly used refrigerant in many places.
    No e30s again.
    Dec 2018
    Germany
    1990 E30 325i 4 Door
    May i ask, to those with R134a, did you guys "upgrade" the condenser and fan? R134a really needs that parallel fins/tubing design and much more air (from the fan) compared to R12.
    It is never a"must" but really recommended to get the most out of R134a conversions on R12 systems.
    Dec 2005
    No e30s, again :(
    I never did on my cars that I converted to 134.
    No e30s again.
    Dec 2018
    Germany
    Quote Originally Posted by superj View Post
    Cooling is fine? no issues?
    Dec 2005
    No e30s, again :(
    It was, back in the day when i had ones that were running 134. Now all the e30s at our house run propane and cool very well
    No e30s again.
    Sep 2014
    KS
    e24e30e36e39e90
    Do you use the camping propane canisters to charge the system?
    Dec 2005
    No e30s, again :(
    I do. They say you shouldn't because they have more moisture than pure propane but i have never had trouble
    No e30s again.
    Joliet,IL
    87 325is 96 GMC Suburban
    I got a tell you, I’ve been into E30s for quite some time and this is definitely the first time I’ve ever heard of fixing the AC with propane! Thats some McGuyver stuff at its finest
    Dec 2005
    No e30s, again :(
    its actually very old, in other forms of transportation and cooling systems. 18 wheelers used to use it regularly in their trailer cooling systems, lots of agricultural places used to use it. people use it in their home systems, as well.
    I did a lot of googling and reading when I first heard about it because so many people automatically say you will burn to death is you get a leak but riding around with a tank of gas has more fire potential than half a green canister of propane, and people have no issues riding around with 12-20 gallons of gas under them. once I found out about it being used in 18 wheelers and farmers using it in everything, I decided to try it out. I still kept reading but learning about the molecules being larger and the fact that you won't lose the refrigerant from seeping out of non-barrier hoses, I felt better about it.
    I had to make an adapter to hook to my r134 charge line but after that, no problems
    No e30s again.
  1. AC help
    By justin23 in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 05-17-2004, 05:40 PM
  2. Constant Heat & AC -- HELP!
    By crosbo in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 12-22-2003, 01:23 PM
  3. ac help
    By laocoholic in forum 1991 - 1999 (E36)
    Last Post: 07-30-2003, 02:03 PM
  4. What Wheels to get?! MVR or ACS?? HELP!!
    By Salar in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 07-29-2003, 02:01 PM
  5. AC help Thanks
    By Saul in forum 1992 - 1999 M3 (E36)
    Last Post: 07-01-2003, 09:29 AM
