Results 1 to 19 of 19
Thread: Need help on Engine oil
    Feb 2019
    el paso
    1985 BMW 325e
    I have a 1985 BMW 325e with 76,000 miles. I am soon will do an oil change. I need some advice. I was told to use Liqui Moly Premium 5W-40 Synthetic Motor Oil (part number #2041) because its the best. The question is this the right oil? I ask because on Autohousaz says it fits my car but when i go to other websites it says it doesn’t. I need some help
    May 2010
    Officially in Tampa
    87 Cabrio & 87 ETA
    The book says 20-50 and if you prefer synthetic M1 15-50 has the zddp our engines need. 5-40 is too thin especially in tx
    87 Zinno Cabrio 98k Barn Find. Build thread http://www.r3vlimited.com/board/showthread.php?t=268987
    87 Lachsilber ETA Time Capsule. bought w 125k from 87yo original owner
    Cabrio deck lid & hinge struts (w sleeves) now for sale. See the link below for more info
    New "made in Europe" seat shocks. PM for details
    http://www.bimmerforums.com/forum/sh...ot-Seat-Shocks
    Oct 2003
    Seattle
    99 M3
    Where do you live? How are the temperatures?
    Feb 2019
    el paso
    1985 BMW 325e
    I live in El Paso texas. I keep on hearing to put 5-40
    Feb 2019
    el paso
    1985 BMW 325e
    In a statement I found out in the link below, says: Based on modern oil chemistry, the best oil for the E30 is a 5W-40 Synthetic. Yes the booklet states to use 20-50 oil, but that was in that year 1985 timeframe. I think it will be ok to use 5W-40. I had a BMW Mechanic also recommend me the 5W-40.
    https://www.e30zone.net/e30wiki/index.php/Oil
    May 2010
    Officially in Tampa
    87 Cabrio & 87 ETA
    If you look enough you will find something to support virtually any opinion. 5-40 is too thin but it sounds like you had your mind already made up before you asked. Your car, your choice.
    Feb 2019
    el paso
    1985 BMW 325e
    Oh no, I don't have my mind set up, that is why I ask for help, I want a recommendation from other E30 owners. I want to put the right oil on the car. So my other question what oil brand do you recomend because I have see that is very hard to get a Synthetic SAE 20W-50. In fact there are only few brands that I found see below.
    I found this brands and type. What you all think:
    Liqui Moly (20114) 20W-50 Touring High Tech motor oil
    Royal purple SAE 20W-50
    Castrol GTX high mileage 20-50
    Amsoil Premium Protection 20W-50 Synthetic Motor Oil
    Jan 2016
    Ca
    2001 525it
    Then go for a 10w40
    Sep 2016
    Texas
    '92 BMW 318i Convertible
    Shell Rotella 15W-40 was recommended to me and works great (Texas), also inexpensive and widely available. Read up on the zddp jeff mentioned.
    '92 318i Cabrio- Alpine White
    Dec 2005
    corpus christi, texas
    No e30s, again :(
    I run rotella in the e30s also. its a great oil that you can get at Walmart. and I am in corpus so our temps are very similar
    No e30s again.
    Sep 2016
    Belgrade
    Saskatoon, Canada
    '88 320i Mtech2; 2004 X3
    this debate will never be solved .... it is something like do you prefer boxers or briefs ....
    - each of the oils mentioned above are good and will work fine in your e30
    - I have used synthetic Castrol Syntec 5W40 for years with no problems
    - or you could use Castrol 15W50
    ... forty-three years of driving before I get behind the wheel of a BMW .... and I am thinking, "why did it take me so long?"
    ... and then after another 4 years I can't believe that I have two of them !!
    Jan 2019
    Evansville,IN
    87 BMW 325i Convertible
    i run rotella t6 5w-40 in my 2002 kia sedona and 92 gmc sonoma 4.3l. I got m1 15w-50 for the e30 but have wondered if i could just use the rotella. It is much cheaper and i have had great results from it in my other vehicles. Next time i do an oil change, i may just do that. So which? 5w-40 or 15w-40?
    1987 BMW 325i Convertible
    “Speed has never killed anyone, suddenly becoming stationary… that’s what gets you.”
    Jeremy Clarkson
    Dec 2005
    No e30s, again :(
    run the same one you use in your Sonoma, would be my guess. I think that is the viscosity we run in the ones we have.
    I almost put it in my Sonoma when I did the oil last week but since it was the first change I have done since I got it, I went with normal oil to start
    No e30s again.
    Mar 2012
    Hopewell Junction, NY
    1987 325iS...edan
    You can probably run virtually anything and be completely fine.
    That being said, I consulted BMW, Mobil, and the comprehensive list of oil test data at 540 rat's site and Mobil 1 0W-40 is the best combination of performance, durability, ZDDP, and price there is. Extremely high shear protection, ridiculous thermal breakdown resistance, very low cold start viscosity, plenty of hot viscosity, and readily available in Walmart.
    FYI it's recommend to run above 1,000ppm ZDDP in these cars. If you can't find that data about a particular oil it's a bad sign.
    Interested in vintage cars? Ever thought about racing one?
    Info, photos, videos, and more can be found at www.michaelsvintageracing.com!
    Elva Courier build thread here!
    Feb 2019
    el paso
    1985 BMW 325e
    That is good information, thanks. I thing it confuse me on high viscosity oils is that for example I was looking for the 20W-50 and a lot of oils it says that are for motorcycle.
    Dec 2018
    Germany
    1990 E30 325i 4 Door
    Quote Originally Posted by Jeffnhiscars View Post
    I agree but i think 20w is a bit thick, though i am not familiar with e engines.
    I use 15w50 from motul (4100 i think) winter or summer the engine loves it.
    May 2010
    Officially in Tampa
    87 Cabrio & 87 ETA
    Quote Originally Posted by H.J. 1981 View Post
    Hes in Texas....nothing is too thick. The silliest part of this conversation is that unless you race, get your oil tested or put a couple of 100 thousand miles on your car you'll never know the difference. They all "sound fine" when you start them.
    i met a Toyota mechanic who, rather than actually work on cars, he sat in the middle of the shop floor with a laptop and answered questions for all the other techs. I asked him how often I should change the oil in my Tacoma and his exact words were "every 5k if you want it to last 100k, every 3k if you want it to last 200k".
    month to month or even year to year as long as you change it and its a reasonable weight, youll never know the difference.
    Vancouver, BC, Canada
    2K 540 Sport 6 Spd
    The truth is more likely that you will never know, if you use a reasonable oil, and change frequently.
    20w50 is pretty extreme. If the engine tolerances we're designed for that viscosity, is one thing, but they would have to be pretty larger.
    My suggestion would be to use real oil pressure gauge to see the hot pressure at higher RPM, with the 20w50, and the use an Xw40 type oil to compare, ensuring you are maintaining adequate oil pressure with the thinner oil.
    Some guys are still trying to use really thick oil on the new BMW ultra tight rod bearing clearances. Almost guaranteed rod bearing failure.
  1. need help swaping engine
    By blown330 in forum 1992 - 1999 M3 (E36)
    Last Post: 07-26-2004, 04:38 PM
  2. Need help on engine swap!!!
    By M3ti bimmer in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 12-28-2003, 02:32 PM
  3. Need Help: Check Engine Light came on
    By OG Skooler in forum 1992 - 1999 M3 (E36)
    Last Post: 05-10-2003, 07:57 PM
  4. Need help with engine noise and ESS SC
    By PDX///M in forum Forced Induction
    Last Post: 11-05-2002, 04:42 PM
  5. need help with diff oil change
    By wewu in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 08-25-2002, 12:26 AM
