Results 1 to 9 of 9
Thread: Wanted - Trans Output Flange
    Vestal, NY
    E30S62, E21S54, E31S85
    Hey guys, I'm looking for a transmission output flange, P/N 23211224970 - Meant for a ZF Trans.
    Most E36, E46, E39, E32, E38, and Z3 models, auto or man trans.
    Anyone have a trans lying around they can pull a flange off for me?!? Thank you for your help!
    Frank Macaluso - BMW Drivetrain Transplanter
    Frank Macaluso
    http://www.garageaholic.build
    BMW Engine Swaps
    Current Swap 2016 LT1/6 into E24 6er
    607-953-9587
    Contact@garageaholic.build
    VA
    1987 325ic
    Quote Originally Posted by Garageaholic View Post
    Here's one.
    https://www.ebay.com/itm/BMW-5HP30-O...-/183785350131
    Vestal, NY
    Quote Originally Posted by cascios View Post
    Here's one.
    I wonder if that one will work I’ll ask! Maybe my search criteria was off but I didn’t see it there on eBay
    Sent from my iPhone using Tapatalk Pro
    Frank Macaluso
    BMW Engine Swaps
    607-953-9587
    Dec 2013
    People's Republic of MD
    22 doors and 4 tops
    What the F is that!
    I have a couple ZF auto's collecting dust
    text me
    Greg
    410-967-6170
    Vestal, NY
    Quote Originally Posted by 66 6 View Post
    What the F is that!
    text me
    Greg
    410-967-6170
    Yesssssss! I’ll call you in a couple hours with some measurements to take too just to be sure.
    This is for an n54 swap in my e36, so need to downgrade the flange size to match the e36 m3 driveshaft size
    Frank Macaluso
    BMW Engine Swaps
    607-953-9587
    Vestal, NY
    Hey guys so i think I misrepresented what I needed, but I think I'm one step closer.
    BMW Part 23211282442 is the output flange for the E46 M3. I think this will work, but I need to know what the Tri-Prong Hole distance is between them. The ECS part link is here: https://www.ecstuning.com/b-genuine-...e/23211282442/
    If someone could take a quick measurement of the tri-prong hole distance that would be amazing. I'm looking for 2.8" +/-. I know they come in standard sizes, so that size is what I need. And yes this is for a ZF and my current output shaft is more like 3.5", so too big.
    Thank you for all who respond!
    Frank
    Frank Macaluso
    BMW Engine Swaps
    607-953-9587
    Jun 2005
    New England
    F90 M5; E36 M3 Turbo
    Are you trying to connect an E90 335i GS6-53 to an E36 automatic driveshaft?
    The ZF320 flange is 96mm; the GS6-53 flange is 105mm.
    You might also be able to find the front half of a BMW driveshaft with the 105mm mating flange that will swap onto the rear half of an E36 driveshaft. Not sure which and some experimentation may be required.
    Vestal, NY
    Yes I’ve thought about swapping the front half driveshaft actually. An idea I’m keeping on the back burner for sure while I still keep on looking for the ideal flange.
    I am going to now take the front half of my e92 335xi driveshaft and see if it makes the the back half of the e36 m3 auto driveshaft.
    In the meaning I did buy an eBay e46 m3 flange . Should bolt on to the GS6-53. Standby as I make more progress!
    Frank Macaluso
    BMW Engine Swaps
    607-953-9587
    Jun 2005
    New England
    Let us know about the E46M3 flange bolting into the GS6-53. I think the input shafts differ in spline count but don’t know about the output. I think the E46M3 flange diameter is the same 96mm as the ZF320 so it if fits the GS6-53, it will mate to a later E36 driveshaft (early Getrag 250 shafts had a smaller front flange), but you still need a shorter overall length like maybe from an automatic E36 or some other BMW.
  1. wtb e36 trans output flange
    By sjrider in forum BMW Parts Wanted
    Last Post: 09-26-2011, 07:16 PM
  2. WTB: trans output flange
    By dreamer420 in forum E30 Parts Classifieds
    Last Post: 04-15-2011, 07:04 PM
  3. Play in 6spd trans output flange?
    By paulmer in forum 1988 - 1996 (E34)
    Last Post: 01-14-2011, 08:13 PM
  4. WTB: 5-Speed Trans. Output Flange
    By ianpringle in forum 1975 - 1983 (E21)
    Last Post: 06-22-2010, 07:49 AM
  5. WTB E30 trans output flange AND Drivesahft
    By JGood325 in forum BMW Parts Wanted
    Last Post: 11-10-2005, 10:37 AM
