Results 1 to 12 of 12
Thread: E34 Belt Tensioner Pulley Torx Size.
    Mar 2014
    Rotterdam, NY
    2011 BMW 328xi Auto
    Hi all, 1995 525i 5SPD 284k
    I'm trying to remove the tensioner pulley and I'm using a torx 50 bit and it's on there very tight but, I'm afraid I will strip the bolt. Am I using the right torx size?
    Thanks in advance.
    moroza's Avatar
    moroza is offline MORΩN ΛABIA BMW CCA Member
    BFE
    E34T
    Mar 2005
    NH
    E34 540i 6sp 1995-03-28
    all mine are 13 mm hex bolts
    Mar 2014
    Rotterdam, NY
    2011 BMW 328xi Auto
    Thanks! I haven't tried an allen. The torx 50 fit ok but, had a little play and that bolt is on tight.
    Jan 2017
    Carrboro, NC
    '91 525i (5sp)
    It depends... Your best bet is to take a look with an inspection mirror. Mine had an allen originally, but it seems new ones only come as torx, don’t remember if 50 or 55.
    NW suburban Chicago
    hiss by my window
    I think you might be trying to remove the pulley from the tensioner which does not have a replacement available. Two M8 bolts w 13mm heads hold the tensioner to the OFH.
    Mar 2014
    Rotterdam, NY
    2011 BMW 328xi Auto
    Quote Originally Posted by ross1 View Post
    So, basically the belt tensioner is one unit and the pulley is not interchangeable?
    NW suburban Chicago
    hiss by my window
    Quote Originally Posted by drewusmaximus View Post
    One is, one isn't. I forget if the hyd or mech one is replaceable.
    I see to remember removing a torx screw on one that turned out to be the "isn't" one.
    I can dig through some of my old parts later and see if I can refresh my memory.
    Meanwhile I suggest you look into if a replacement pulley only is available. I had thought I'd found the replacement for this once and it/I was wrong.
    Sorry to be so nebulous but memory is foggy
    Jan 2017
    Carrboro, NC
    '91 525i (5sp)
    Hydraulic one is definitely replaceable; I know zilch about the mech one, though...
    NW suburban Chicago
    hiss by my window
    Just looked some of my old stuff. Yours is the mechanical type which means you are SOL for finding the pulley alone.
    You can buy the entire tensioner 11 28 1 735 899 $15 Dorman(china) @ Rock Auto to $45 for OE INA @ Amazon
    Supposedly #s ending 748 832 & 427 252 are exchangeable, I only searched one #, might be worth sniffing around using all the #s for better price
    Mar 2014
    Rotterdam, NY
    2011 BMW 328xi Auto
    Interesting... I know the idler pulley is interchangeable but, I agree I have the mechanical. I read I can upgrade to the hydraulic. I'm not going to push it. I'll look for a mechanical. Thanks for your advice.
    NW suburban Chicago
    hiss by my window
    hydraulic is not an upgrade IMO, just different.
  1. E34 front door panel torx size??
    By white525i in forum 1996 - 2003 (E39)
    Last Post: 08-03-2005, 01:53 AM
  2. Accessory Belt Tensioner Pulley Bad
    By M Roady in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 02-16-2005, 10:31 PM
  3. Part List: Replacing Belts & Tensioner Pulleys
    By moonluv810 in forum 1992 - 1999 M3 (E36)
    Last Post: 03-02-2004, 05:22 PM
  4. SF Bay Area - Need Belt Tensioner Pulley...
    By ///Dom in forum California sponsored by Avus Autosport
    Last Post: 08-11-2003, 08:29 PM
  5. WTB: air condition belt tensioner(pulley)
    By BMWFAN in forum BMW Parts Wanted
    Last Post: 03-22-2003, 10:47 PM
