Hey all,
If anyone is interested I have a set of 4 almost new (1500 miles on them) 275/35/20 Michelin pilot sport a/s 3+ for sale. They are the same diameter as stock at 27.6" but about 1 1/2" wider. I'd take $500 for the set plus the ride or you can pick them up.
FWIW, 27.6" is not stock diameter, it's a bit taller. Stock E38 tires are all in the 26.6 - 27.3" range.
I have an '01 IL that came with 225/60/17 which are 27.6", are these not a stock size?
If they're a stock size I haven't seen them listed anywhere. Stock for 17s would have been a 235/55R17 from what I've seen. 27.6" is certainly within the range of what'll fit the car, however (provided they're not super wide).
Yeah - you got some odd sizes there. The door jamb - drivers door has the label, which shows you the correct / factory sizes. Other than Protection ( armored ) 740’s - none came factory with a 17 inch wheel.
I believe you could get 17” style 70 wheels on a non-protection E38. Not sure what size tires though. Where’s Q?
http://www.bmwstylewheels.com/bmw/70
They are style 70s and came with run flats
At any rate, the 17 inch tire specified for any e38 is 235/55/17.
