RM European Auto Parts
Results 1 to 13 of 13
Thread: Geyser coming from expansion tank when thermostat opens
    May 2019
    Sc
    got a 2000 323 and its bubbling a small amount when cold up through the radiator cap. I've replaced the water pump,thermostat, all hoses, pulled the radiator and made sure its flowing through it like it should.
    When its first cranked with the cap off you can see small bubbles coming up through the expansion tank. When the thermostat opens it's like a geyser blowing out the expansion tank.
    I just did a compression test on it. All plugs look normal and dry, compression is from 170 to 190 cold and dry.
    Anyone have any suggestions.
    Thanks ,Thomas
    You're getting compression gasses into the cooling system. You've got a bad head gasket, or cracked head, or warped head. Time for major repairs.
    May 2019
    Sc
    What's the ball park charge for a job to fix it
    dworthy's Avatar
    Nov 2010
    Grafenwoehr, Germany
    16 220i 05 325it 05 M3
    A new engine isn't cheap, and about 8 hrs to install, so ballpark of 1.5k to 3k depending on location, ect.
    Darin
    Current:
    Past:
    79 525 euro Green/Green RIP
    M-Flight Member
    8 hours to install? Not a chance! Maybe actual time, certainly not book time. Even warranty pays about 15 hours on a 4 cylinder. I can't even do an N20 in less than 10 or 12 hours. I can't see an E46 going any faster than an N20
    dworthy's Avatar
    Nov 2010
    Note I said install, not pull out and swap.
    Typically I can do it in 7 hours if everything come apart smoothly, but on a 20 year old car, not happening. Remember that these older cars have less wiring to mess around with than the N20 motor, no turbo.
    Darin
    Current:
    Past:
    M-Flight Member
    Joppa, Md
    99 M Coupe,04 K1200rs
    Quote Originally Posted by White94RX View Post
    I can't imagine how an engine swap could take so long, albeit, I'm old school, but have never needed more than 2 hours to pull an E24/28/30/36, with tranny?, guibo,bitch clip, tranny & eng.mts, a few wires,fuel & p/s lines, radiator and hoses, head pipe nuts can be a problem,but a torch is fast.,and I'm on the floor, no lift..
    Like you said, old school. I'm sure it's a lot simpler on those cars. I can typically have an N20 out of the car (cradle, engine, trans, on the engine lifting table) in about 2 hours. Swapping everything over is where the time gets eaten up. N63's, which I have done more than I could ever count), still take 2.5-3 to get out of the car and on the ground.
    Joppa, Md
    I hear ya, a couple of tranny bolts on my son's 300 z twin turbo took about a half hour,and every extension I own.!
    Jun 2002
    Aberdeen, NC (yes, again)
    E39M5, E500 4WD
    Excuse me?
    8 hours out, eight hours swap parts, eight hours in. Twenty four hours . That is book time. If there's someone here who can swap an M52 Tu or M54 in an E46 in eight hours, have fun. I do not want to watch.
    Chris Powell
    BMWCCA 274412
    Thank God someone to back me up, Chris! I feel like I was even being optimistic on my times I posted.
    dworthy's Avatar
    Nov 2010
    Yes we all know book time, which is at times, can be a bit off. I am not saying that it won't take that long, for we all had a motor or two that crap just didn't want to come off.
    If you are getting a junkyard motor, then most of the stuff is still on the engine, now if you want to use those parts is another story.
    I've had jobs that took 4 hours to complete and the book said 2, Murphy is always hanging around to throw a wrench in stuff.
    Darin
    Current:
    Past:
    M-Flight Member
    Joppa, Md
    Excuse me?
    Us old schoolers are particularly annoyed at jobs that were minutes in the past, now hours, like any 3/4 speed from the muscle car era was a 10 minute removal, clutch was another 10, bell housing could stay on!.
  1. Geyser coming from expansion tank when thermostat opens
    By WEDGEHEAD01 in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 05-14-2019, 08:48 AM
  2. Expansion tank and thermostat - just pay shipping
    By lewvirg in forum 1995 - 2001 (E38)
    Last Post: 08-02-2017, 04:00 AM
  3. E36 Expansion tank, hoses, Thermostat Housing, Coolant hardpipe & Free Parts
    By Barbic in forum Engines, Performance Parts & Software
    Last Post: 07-06-2012, 04:29 PM
  4. remove expansion tank w/o opening system?
    By dsmblue in forum 1991 - 1999 (E36)
    Last Post: 12-31-2010, 02:17 AM
  5. Replies: 11
    Last Post: 10-21-2005, 01:15 PM
