Results 1 to 10 of 10
Thread: question on timing s52
    Jan 2019
    houston
    2017 F150, 97 M3
    I have the motor at TDC, cams at TDC (double dots pointed straight up on intake and exhaust cams). Slots properly aligned for vanos in front cam gears...Now I still have the 4 torx on the exhaust cam gear loose, but I have tightened down the ones on the intake cam with the proper installation of parts (2mm spacer, then spring/disc with bow outwards, and 4mm spacer). I cannot turn the smaller vanos chain side to side anymore once tightening down the intake cam gear. Is this normal?
    I have these gaskets left over right now, where do they go?
    Where I have the red arrow pointing to the seem in the vanos unit, does a gasket go between those two mating surfaces?
    Jun 2005
    New England
    F90 M5; E36 M3 Turbo
    The gaskets might be from your front timing cover.
    Ottawa, ON, Canada
    e90 M3,X5,e46 racer
    Lol ... yeah, kinda important
    There is no gasket in the vanos (but there is one between the vanos and head)
    Check out the 8legs Racing page: https://www.facebook.com/8legsRacing/
    Jan 2019
    houston
    2017 F150, 97 M3
    Figured out I ordered dupicates so I have an extra...but any ideas on why the intake cam gear doesn't spin now? I am under the impression that it should as long as the exhaust cam is loose.
    Jan 2006
    Oakhurst, CA
    96 M3 97 M3 98 M3 99 M3
    It should turn with force, you assembled an engaged clutch pack of sorts. Are you using the lollipop tool? Make sure the 4mm spacer is on the shafts and not stuck on the shoulder.
    Jun 2005
    New England
    Lollipop tool is great. Hard to turn without it but it can be done.
    Jan 2019
    houston
    2017 F150, 97 M3
    Ok you two have made me feel better....I was under the impression it was supposed to turn with the same easy it does before I bolt the 4mm spacer over the diaphgram spring! After I bolt that 4mm spacer over the diaphram spring I have been gripping the chain by hand and moving it back and forth, but could not do it with the spacer torqued to the 7 foot pounds, only with the nuts barely threaded on. However no problem with the lollipop tool.
    Jan 2019
    houston
    2017 F150, 97 M3
    Last night I got the vanos back on, because according to my how to video I was watching on youtube, you assemble the vanos onto the motor before spinning it over twice to check your still at TDC. I did this and eixhaust timing is perfect, but looking from front of motor, on the intake cam I could fit a nickel under the right side of the timing block (not perfectly flush). Can I put the motor at TDC (on dampener), loosen the 4 torx bolts on the exhaust cam sprocket, then grab the intake cam with a crescent wrench in the middle and rotate it clock wise the tiny bit needed to make the cam lock block sit flush; all while leaving vanos installed?
    Jun 2005
    New England
    There is a little play around TDC. Make sure you are recognizing the angle of the mark on the block when you line up the trigger wheel. Hold the mirror at the same angle.
    Also, don’t back into TDC after having gone past it. Time as you are just hitting TDC on your rotation.
    See if you get any closer to perfect after 2 rotations.
    FL
    are slow.
    It should turn with some force. Obviously not a crazy amount of force, but it will turn if set properly. (Remove the timing blocks if turning).
    Those gaskets go on your front timing chain cover. They need to be installed. The VANOS unit has a gasket between the bottom half of it and the cylinder head, and that needs to be in place as well.
    I highly recommend the right tools for this job, and you really should have the lollipop tool. Me and many others on this forum would be happy to let you borrow the right tools for the job. See sig for how the blocks should sit.
    -Dr. Seuss
  1. clutch question - s50 vS. s52
    By neal1st in forum 1992 - 1999 M3 (E36)
    Last Post: 08-05-2005, 09:09 PM
  2. Question: M52 to S52 swap??
    By PALELLA in forum 1992 - 1999 M3 (E36)
    Last Post: 06-29-2005, 05:47 PM
  3. simple question this time
    By dtoytwinturbo in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 12-17-2004, 08:53 PM
  4. Question about timing and compression ratio's
    By NoSoup4U in forum Forced Induction
    Last Post: 01-31-2004, 02:17 PM
