RM European Auto Parts
Results 1 to 7 of 7
Thread: 4 Dash lights, DSC, ABS, Ebrake, brake wear
    May 2019
    Cherokee, IA
    2001 BMW 325xi Sedan
    I just bought a 325xi 2001 recently and knew the lights were a problem, I'm wondering what way I could fix this. I have a Yellow DSC light, yellow ABS, yellow brake wear, yellow ebreak. These always stay on starting the car, but just recently I started in the morning (cold start) at around 7 A.M when it was still kind of wet from dew and the humidity was pretty high, and cold outside, the lights all went away until I got home where I turned it off and started it again a little later they came back on.
    dworthy's Avatar
    Nov 2010
    Grafenwoehr, Germany
    16 220i 05 325it 05 M3
    Welcome to the Forum!
    Well more than likely you have a bad ABS sensor. The best way to find out which one is to use a Diagnostic tool to communicate with the DSC ECU.
    Darin
    Current:
    Past:
    79 525 euro Green/Green RIP
    M-Flight Member
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    Find a reputable indie shop that specializes in bimmers at www.bimrs.org. You’re in Iowa so that website may not show any shop that’s nearby. I don’t know if the NMW Car Club of America has a chapter in your area but google “BMW CCA #####” where “#####” is your zip code. That’ll give you the link to the local chapter. See if there are recommendations for any shops.
    Diagnosing your problem requires software running on a laptop (for portability). Check the software sub forum for info.
    May 2019
    Cherokee, IA
    Ive heard if the ebrake light is also on that means its one of the back ones, is that true?
    Jul 2004
    Houston, TX
    36 Cylinders
    If you can, get a scan. It's often cheaper than guessing.
    I put this base pack for diagnostics from BMW here, everything you need is in post 1. You only need a K+DCAN cable (the ones with a switch) and a Windows laptop.
    https://www.bimmerforums.com/forum/s...xperimentation
    Alternatively, the Foxwell / Schwaben tools may be good for this.
    -Abel
    - 2000 Z3: Many Mods.
    - 1999 S52 Estoril M Coupe
    - 2016 Mini Cooper S
    dworthy's Avatar
    Nov 2010
    Quote Originally Posted by Teckus View Post
    Nope, not always. Does your speedometer work?
    Darin
    Current:
    Past:
    M-Flight Member
    May 2019
    Cherokee, IA
    Yes my speedometer works but my cruise control doesnt, i also hsve a speed sensor a code so i will be pinpointing which one it is and replacing it
  1. Replies: 51
    Last Post: 09-27-2016, 10:43 PM
  2. DSC, ABS and brake warning lights come and go...what gives?
    By jaugustavo in forum 1995 - 2001 (E38)
    Last Post: 01-29-2010, 07:20 PM
  3. Christmas tree lights? DSC + ABS + Emergency Brake at start-up.
    By andrewmacc in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 09-14-2009, 07:42 AM
  4. DSC/ABS/EBrake Lights
    By gofastr in forum 1999 - 2006 (E46)
    Last Post: 01-10-2009, 08:25 PM
  5. Need Help DSC, ABS and Brake Light came on today any ideas
    By pass427 in forum 1988 - 1994 (E32)
    Last Post: 10-26-2005, 06:39 PM
