Results 1 to 10 of 10
Thread: BMW 323i Running bad after sitting
    May 2019
    Queens, New York
    2000 BMW 323i
    Hello I just bought a 323i bmw manual that was sitting for over 2 years. It was running fine before no problems. When I went to drive it home the coolant started leaking and the engine overheated. The brakes didnt feel powerful enough maybe the brake fluid was low. The transmission makes grinding noise going into gear probably a tiny gunshot noise it was weird. After stopping to the side of the road putting in water in the radiator since I didnt have coolant and it was an emergency the car didnt overheat or leak coolant again drove fine except for the transmission and brakes.
    Would I need to change all fluids since it was sitting for this much time and now its running bad? Transmission, brake, oil, steering, coolant.
    dworthy's Avatar
    Nov 2010
    Grafenwoehr, Germany
    16 220i 05 325it 05 M3
    Welcome to the Forum!
    There is a good chance that the fuel has gone bad if there was no stabilizers added.
    Brakes are going to be a problem, for I am sure they are rusted over, so all new pads and rotors.
    Fluids and a tune-up would be called for in this case, and worth the investment if you plan on making the car a daily driver.
    I am assuming it is a manual gearbox?
    Darin
    Current:
    Past:
    79 525 euro Green/Green RIP
    M-Flight Member
    May 2019
    Queens, New York
    2000 BMW 323i
    Yeah it is a manual gearbox. I'm going to check the transmission oil if its good.
    dworthy's Avatar
    Nov 2010
    I am willing to bet that it has never been changed. Also have a look at the diff too, while you are under there.
    Pro tip: Always open the fill plug before you remove the drain plug.
    Darin
    Current:
    Past:
    M-Flight Member
    May 2019
    Queens, New York
    2000 BMW 323i
    Okay will do. The rear axle was making some noise will check that diff. I'm not going to see the car until weekend
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    The car has an engine made from aluminum. Do not overhear the engine or you’ll be stuck with a 500 pound paper weight!!! The entire cooling system needs to be replaced with an E46 (BMW’s chassis designation) of that age. Installing aftermarket cooling system parts is strictly verboten!
    May 2019
    Queens, New York
    2000 BMW 323i
    Yeah I'm looking into the coolant overhaul kit
    May 2019
    Queens, New York
    2000 BMW 323i
    Hello, my scanner picked up dtc codes which are p1250 BMW, p1519, p0170, p0173, p1189, p1188. My guess is that these codes came up because the gas went bad or oil since it was sitting and not changed. I will refill the gas and use marvel mystery oil. Also could be the MAF sensor or fuel pressure regulator as other people in this forum experienced
    Apr 2013
    Mill Valley, CA
    2003 330cic
    In order:
    1. Fuel pump and filter. I would just replace the filter, then check fuel pressure at the rail with the key at position 2 with engine off. Should read 50psi
    2. Vacuum leaks. All the vacuum hoses, both intake boots, CVV. Just replace. Then check DISA and dipstick rings. Smoke test after all this to see if you have vacuum leaks in the engine
    3. Sensors. If your pre-cat sensors are over 100k (125k if broadband) then replace them. Probably also issues with MAF
    Look at your long term fuel trims with OBDFusion and your phone. Ideal is +/- 2%
    May 2019
    Queens, New York
    2000 BMW 323i
    Quote Originally Posted by harrier View Post
    In order:
    Thanks will test in order
  1. Is it normal for car to start/run badly after sitting for a few days?
    By Stick Shift in forum 1992 - 1999 M3 (E36)
    Last Post: 03-09-2009, 09:08 PM
  2. 540 runs poorly after sitting at night - intake leak or what?
    By resinears in forum 1996 - 2003 (E39)
    Last Post: 10-30-2007, 11:56 AM
  3. car running bad after rain
    By thedude60126 in forum 1991 - 1999 (E36)
    Last Post: 08-24-2007, 12:10 PM
  4. car running badly after car wash
    By daddycam in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 08-07-2004, 02:27 PM
