Results 1 to 10 of 10
Thread: Oil light comes on at startup
    May 2019
    Warren county NJ
    2000 323i, 2003 SL55 AMG
    Hi all,
    I'm a newbie to the forum. This is my first post and I'm hoping for some feedback. I have a 2000 323I and bought it 6 months ago. Can't seem to stop my Amber oil pressure light from appearing for about 10 seconds upon startup every time, without fail. I changed the oil pressure sensor 2x already. Can't stop this thing from turning on every time I start the car. The light doesn't come on at any other time- either idling or driving. Only for those 10 seconds. Any ideas? Thanks
    Mar 2019
    ATLANTA GA
    456 X3s
    mjd718: have you checked the oil level...was the oil level sensor oem? I'm only familiar with the opposite meaning the oil light stays on several seconds 10 Once you turn the car off after driving .....check your owner's manual see what it says about this issue
    Sent from my SM-J727T using Tapatalk
    Mar 2015
    west chicago il
    01 E46 330i 5sp man spor
    Yellow oil light is either low oil level (check oil) or a faulty oil level sensor. If the oil level is ok, replace the oil level sensor at the next oil change. Use hella brand sensor.
    Sent from my S61 using Tapatalk
    Apr 2013
    Mill Valley, CA
    2003 330cic
    Quote Originally Posted by mjd718 View Post
    Hi all,
    That is the indicator for a failed sensor. Buy a new one on FCPEuro and install next time you change your oil. Until then check the dipstick every time you fill the tank.
    Peoria, AZ
    03 zhp, 97 e36m3, 04 zhp
    Plausible values error will be stored in computer's memory if you indeed have an issue with the sensor - have it scanned instead of throwing $ away. Also, make sure your car side plug of the sensor isn't damaged/corroded/loose.
    Apr 2013
    Mill Valley, CA
    2003 330cic
    Quote Originally Posted by Mless5 View Post
    The yellow light that stays on for about ten seconds at ignition is literally the signal from the computer that the level sensor is not working correctly. It is like a seat belt not fastened light.
    In this case you don’t need a weatherman to know which way the wind is blowin’...
    Jan 2015
    Timaru, New Zealand
    Two Z3 Roadsters
    You mentioned that you have changed the oil pressure sensor already. The oil level sensor is in the bottom of the oil sump and is different to the pressure sensor.
    1999 2.8L Z3 Roadster,
    2000 3.0L Z3 Roadster,
    Feb 2015
    Irmo, SC
    328Ci, 335i, 330Cic
    +1 for oil level sensor on bottom of oil pan.
    Sent from my SAMSUNG-SM-G930A using Tapatalk
    Jan 2016
    Ca
    2001 525it
    Yellow oil level, red oil pressure
    Mar 2019
    ATLANTA GA
    456 X3s
    Quote Originally Posted by jclausen View Post
    If I'm interpreting right yellow indicates oil level or sensor. and if the icon shows red it's for the oil pressure? So at the start op starts by describing a amber (yellow) pressure light! according to you there is no such thing? Ah! a trick question!
  1. 330i oil light coming on at startup
    By dabagboy in forum 1999 - 2006 (E46)
    Last Post: 11-19-2008, 12:48 PM
  2. How many sec for oil light to go out @ startup
    By MVEED3 in forum 1992 - 1999 M3 (E36)
    Last Post: 03-18-2006, 06:12 PM
  3. Oil light comes on after vehicle turnoff
    By bluebimmer320i in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 11-12-2005, 10:09 AM
  4. Oil light comes on at shutoff
    By ix53204 in forum 1999 - 2006 (E46)
    Last Post: 11-18-2004, 02:18 PM
  5. Oil light comes on after a long run up the canyon!!
    By JasonJ75 in forum 1992 - 1999 M3 (E36)
    Last Post: 10-15-2001, 02:19 AM
