Hi guys,
I am currently getting things together for a LS swap into a 2003 E46 coupe.
The majority of people douing this swap use the T56 6 speed and there seems to bee a good bit of information about this swap. What I am looking for is more information and ideas on using the 4L60E auto transmission.
Is there anyone out there that makes a kit for the swap using the auto trans? Specifically the headers, seems the CX Racing headers will not work due to the transmission pan on the auto.
What parts of the CX racing kit will work? I assume engine mounts will, and I would like to use the Holley oil pan.
Can anyone link me to others that have done the same swap (non turbo)?
are you planning on modding it at all? would highly recommend the 4L80E over the 60...
Can't help with the CX stuff in e46 though but i'm sure others can
Well, it will probably be a long term project that will evolve over time. My engine is about 400HP at the crank so obviously I need to support that. I was going to get an upgraded 4L60E with the stronger sun shell and whatever the other standard upgrades are. My concern with the 4L80E is physical size, its already going to be a challenge using the bigger auto trans and I would like to keep tunnel modifications to a minimum.
If I go crazy down the road (years from now) and go turbo I will have to pull the engine for upgrades, so I could upgrade to the 4L80E at that time.
Make any progress on this yet? I'm doing pretty much an identical build.
Slowly but surely. My dad has been visiting from Australia for the last couple of weeks so I put my project on hold. We did recover the headliner and pillars while he was here but I put the heavy lifting on hold.
I have made some tunnel modifications and the trans is really close to fitting. I need to swap out the shift shaft in the 4L60E for a short one from a 700R4 and do a bit more beating on the tunnel.
I did find this.....
https://forum.synergymill.com/t/bmw-...ots-of-pics/23
20190817_171951.jpgThanks for that, always great to see what others have done.
I now have the engine and transmission in the car. I was able to fabricate a simple 3/16" plate to adapt the transmission mount to the BMW transmission crossmember. The TDR engine mounts work perfectly with plenty of clearance for steering shaft, bellhousing and pan. Yesterday I got an ICT Billet, AC compressor bracket, to run the BMW compressor off the LS crank pully.
Next is to see how the cheap Ebay headers fit. I think I will run the drivers side backwards (so as to not have to work around the steering shaft) then down under and back down the passengers side. I may have to buy a second pair for that but at $85 a pair its a lot cheaper than anything else I can come up with. If it all goes pear shaped, I will resort to the $600 CSX swap headers and modify the flange around the trans pan.
Project is coming along nicely now, the weather has cooled off and I have a pretty good plan moving forward. Only 85% to go.
Looking good! Thanks for that bit of info on the trans mount. I'll likely do the same.
The project is moving along slowly.
I have fabricated an exhaust using 2 sets of SS ebay headers, using a passenger side header turned backwards on the drivers side so as not to interfere with the stering shaft. The drivers side then loops back, runs under the AC compressor and joins in to the stock BMW muffler for now. Passenger side header needed the flange moved but then runs normally back to the BMW muffler and then out the existing BMW exhaust. I may look at reworking this later if it turns out to be too restrictive. I wrapped the headers and pipes in Lava wrap and used heat shielding wherever I thought necessary to reflect some heat.
I had a single piece driveshaft made using a BMW CV joint at the end that bolts to the 330 diff.
I used Thaniel's Arduino module to control the BMW gauges, and mounted a VDO oil pressure gauge, fuel pressure gauge and voltmeter, where the ashtray used to be.
I installed a Lokar shifter and wired the neutral safety switch to enable the circuit and illuminate the START button when the shifter is in PARK or NEUTRAL.
I used the empty compartment on the passengers side of the engine bay, at the firewall to mount the GM PCM and my relays and fuses for all things GM related.
just a few more wires to hook up then onto the cooling system.
20191020_142805.jpg20191020_142837.jpg20191025_125241.jpg20191217_072410.jpg20191217_072427.jpg
20191012_174212.jpg20191118_071958.jpggauges in ashtray.jpg20191020_142917.jpg20191020_142817.jpg
The picture of the gauges is not my car, but it exactly what I have copied, minus the black knob.
How much does a hot rod build like this average?
20200129_195605.jpg20200129_195703.jpg20200129_195713.jpg20200129_195649.jpg20200129_195617.jpg
Project Sour Kraut is almost ready to run and would actually fire up in about five minutes, but I am waiting till spring to do that.
Electrical is done with relays and fuses mounted in an opening by the firewall.
Fuel system is plumbed and pressure checked, holds a perfect 50 PSI.
Power steering is connected and using a Corvette pump to power the BMW steering rack.
Cooling system is plumbed. I am using a pair of 90 degree silicone hoses at the bottom connected with a barbed coupler and coming off the stock BMW radiator using the BMW hose connector. At the top I am using a part from CX Racing that adapts the top fitting on the BMW rad to the GM water pump. Heater hoses run through the BMW heater valve to the heater core then back out through a T to the bottom of the surge tank, then on the other side of the engine bay I mounted a vented overflow tank. This should allow the system to purge any air into the surge tank then the system should stay full thanks to the pressure cap and overflow tank.
By chance I was able to adapt the electric Camaro cooling fans that I already had to work with the BMW radiator, the BMW originally had a mechanical fan which is now gone. These are wired through a series of three relays that give me high and low speeds based on pre set temperatures in the engine computer (PCM).
Air Conditioning is one hose and a charge away from being done. I have one hose from the condenser to the compressor that is 3 inches too short. I am using the complete BMW AC system mounted to the GM engine using a special bracket from ICT Billet.
I have mounted three VDO gauges where the ash tray was, oil pressure, fuel pressure and voltage. They match the BMW gauge font nicely (picture to come of this) also mounted a small amber LED that lights when the shifter is in reverse. I used a red lighted START push button that lights in PARK and NEUTRAL and only energizes the starter relay in those positions.
Next thing is a Lokar accelerator cable and bracket. Followed by hooking up the BMW electrical to the headlights and such.
Yesterday I ordered a front end kit with new control arms, bushings, and end links. After that’s all on I will need new brake pads and rotors all round and two new calipers up front. I already have some SS brake hoses ready to go on.
Finally fill the coolant, Power Steering fluid and prime the oil and its done…….until I figure out what I want to do with the rear end and suspension.
Wow, great progress. The goal is in sight!
Diving in at the shallow end!
Got my transmission cooler buttoned up this weekend, also couple of pics of my VDO gauges. Both pressure gauges say Oil Pressure, but one is connected to the fuel rail and will display fuel pressure.
i assume your using a corvette or camero crank pulley
I'm getting ready to start this my self just purchased a 330i last week with a bad engine
would be killer if you had a parts list or part numbers for the brackets, mounts oil cooler, stuff like that if you didnt mind sharing
While I did keep a spread sheet of everything I spent, I didn't keep detail like part numbers.
PM me your email and I will send you the spreadsheets I have, they may be of some use.
Feel free to contact me as you progress through your build and I will be happy to share with you what I did.
How do you like the tdr mounts? I would like to use them with my e46m ls swap project as well. Can you post more pics of your fitment on driver and passenger side header section to get and idea of the space? Thanks
They are beautifly made pieces but I can't speak to how well they absorb engine vibrations as I am not driving the car yet.
The biggest concern is making headers work. I wasn't convinced I could use the CX racing headers without modifications so I bought two sets of Ebay headers and used the passengers side on both sides of the engine, turning the drivers side backwards, or exiting forwards, then routed the pipe around the front of the engine and down the pasengers side. there are a few spots where the exhaust is a bit close to the AC compressor and steering rack, but I have gone pretty crazy with heat shields and header wrap so hopefully all will be well.
When I try to add pics I get a box that says I have exceeded forum quota. If you know how to fix that I can attach some pics.
Any update to this build? I have a e46 and this build is what I’m working off of 😊 because your smarter than me.
What auto transmission did you finally go with? The 60? Besides fabbing a mounting bracket, did you have to do any actual modification (cutting/welding) to the car itself?
