Results 1 to 9 of 9
Thread: Flashing DME
    Jan 2013
    Los Angeles
    02 525i sport
    Flashing DME
    I did a e39 525i to 530i swap, I need to flash my dme with 530i map. My inpa set up came with old version of winkfp 4, will it still be able to flash my dme or do I need a new version? Thanks
    Jul 2004
    Houston, TX
    36 Cylinders
    As long as your flash data is set up, it should work.
    If not, it's easy to update your winkpf/inpa installation.
    -Abel
    - 2000 Z3: Many Mods.
    - 1999 S52 Estoril M Coupe
    - 2016 Mini Cooper S
    Jan 2013
    Los Angeles
    02 525i sport
    Flashing DME
    Ok thanks, just found out I am missing data’s as well, should it be on my cd or do I need to download update date?
    Jan 2013
    Los Angeles
    02 525i sport
    Bump , anyone
    Jul 2004
    Houston, TX
    36 Cylinders
    https://www.bimmerforums.com/forum/s...xperimentation
    I would just use this pack. The Chinese packs from CD are very unreliable.
    -Abel
    Jan 2013
    Los Angeles
    02 525i sport
    Ok thanks I will give it a try.
    This is where I am stuck right now on my set up, can’t see or add data or zb.
    Jul 2004
    Houston, TX
    36 Cylinders
    What ZB number are you attempting?
    -Abel
    Jan 2013
    Los Angeles
    02 525i sport
    E39 eu2 7545679
    Jul 2004
    Houston, TX
    36 Cylinders
    You just need to make sure those files are present in your daten. You may have to load the e39 ms43 folders in there, as well as the gdaten folder.
    -Abel
  1. Problem flashing DME after e46 manual swap. Any insight?
    By kevinwilly in forum Diagnostic Software
    Last Post: 01-28-2024, 08:14 PM
  2. Flashing DME 540i sedan using winkfp
    By obieda94 in forum 1996 - 2003 (E39)
    Last Post: 12-08-2017, 09:31 AM
  3. Flashed dme tune from member hakentt
    By ComradeLinen in forum 1991 - 1999 (E36)
    Last Post: 01-28-2013, 01:47 PM
  4. Help to Re-flash DME to manual trans
    By crashdummy2 in forum Diagnostic Software
    Last Post: 08-24-2010, 01:25 AM
  5. DME Flash Code: Knock Sensor #2 ?
    By ///Arman in forum 1992 - 1999 M3 (E36)
    Last Post: 08-09-2002, 07:59 PM
