Results 1 to 4 of 4
Thread: Front engine sensor seals
    May 2019
    Fallbrook
    2006 E60 530i N52
    Hello, first post on this forum
    Have an 06 530i with the N52 engine. It's my girl's car and it sees the normal maintenance for oil and rotations etc. and I fix things as they come up. I'm finally ready to chase the oil leaks it has and I will be starting with the top of the engine with valve cover and a new bolt kit because the prior owner or some mechanic has stripped some of them out. The oil filter housing seal, and the oil cooler seal are on the first attack as well. However after a few cleans and watching. It has become obvious that some or all of the many sensors at the front of the engine are leaking from their o-rings. I am looking for the best way to replace all of these at once. Is there a kit or any diagram that shows an exploded view of the area I can locate seals for? I do not have any issues with the sensors or any engine light/codes. Just wanting the o-rings for each of the sensors. If anyone has information on this, open to suggestions on where to look for the seals. Thank you
    Jan 2016
    Ca
    2001 525it
    Go to reloem. Com, punch in the last seven of the vin, section 11 is engine scroll thru diagrams, you'll find it
    May 2019
    Fallbrook
    2006 E60 530i N52
    Thank you. Good site. The kind that's specific enough to trust fitment.
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    http://www.realoem.com/ gets more and more slow due to sponsored ads, try this one, faster http://bmwfans.info/parts-catalog
    as for repairs you can use https://www.newtis.info/tisv2/a/en/
  1. 2004 745i engine front cover alternator seal failure
    By jdperna in forum 2002 - 2008 (E65, E66)
    Last Post: 12-30-2016, 09:42 PM
  2. running front crank sensor with obd2 engine harness e36
    By 7808 in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 10-10-2015, 08:35 PM
  3. 2011 bmw 328i engine seal or front bumper cover seal?
    By zhangjunzhe8868 in forum 2006 - 2012 (E90, E91, E92, E93)
    Last Post: 06-11-2015, 12:51 AM
  4. Front Engine Oil Seal - anyone done that..?
    By vvurdsmyth in forum 1983 - 1991 (E30)
    Last Post: 07-22-2014, 06:27 PM
  5. To all Engineers: Sensor Question
    By aceves in forum 1992 - 1999 M3 (E36)
    Last Post: 08-16-2002, 06:18 PM
