Hello, first post on this forum
Have an 06 530i with the N52 engine. It's my girl's car and it sees the normal maintenance for oil and rotations etc. and I fix things as they come up. I'm finally ready to chase the oil leaks it has and I will be starting with the top of the engine with valve cover and a new bolt kit because the prior owner or some mechanic has stripped some of them out. The oil filter housing seal, and the oil cooler seal are on the first attack as well. However after a few cleans and watching. It has become obvious that some or all of the many sensors at the front of the engine are leaking from their o-rings. I am looking for the best way to replace all of these at once. Is there a kit or any diagram that shows an exploded view of the area I can locate seals for? I do not have any issues with the sensors or any engine light/codes. Just wanting the o-rings for each of the sensors. If anyone has information on this, open to suggestions on where to look for the seals. Thank you
Go to reloem. Com, punch in the last seven of the vin, section 11 is engine scroll thru diagrams, you'll find it
Thank you. Good site. The kind that's specific enough to trust fitment.
http://www.realoem.com/ gets more and more slow due to sponsored ads, try this one, faster http://bmwfans.info/parts-catalog
as for repairs you can use https://www.newtis.info/tisv2/a/en/
