Page 2 of 2 FirstFirst 12
Results 26 to 46 of 46
Thread: Jason's '95 M3 3.2L EFR build
  1. #26
    Austin, TX
    S13, Turbo M3
    My basic philosophy on oil control is this. Oil is a lubricant. It’s a shitty coolant and an even worse fuel. The oil is supposed to be between the metal parts preventing them from eating each other, not flying around the crank case being beaten into a froth. Race teams spend considerable effort trying to get as much of the oil out of the crankcase with coatings and trays and dry dumps tuned to pull a vacuum so the oil can’t stay in suspension. Unless you really really need it to supliment the cooling system like Mikes car, I guess I don’t really know why you would want to take perfectly good filtered oil and pump it into the top of the crank case.
    I agree with you there for sure. I think the front sump pan in the E30 application is probably your main problem, because overfilling a stock E36 rear sump pan with a baffle typically works really well to keep the oil where it needs to be under hard acceleration. It's only under quick transitions left to right where I would notice any kind of oil pressure dip on the datalogs at all before going to the euro dual pick up stuff. Have you logged oil pressure during a pass (I assume so?) to see it dip?
    Mike
    IG: @mikevanshellenbeck
  2. #27
    FL
    are slow.
    Lol, I love how this turned from a turbo build thread to an oil thread.
    Just to be clear, you're running an S54 pump, dual pickups, and the S54 pan?
    -Dr. Seuss
  3. #28
    Austin, TX
    S13, Turbo M3
    Quote Originally Posted by Hova View Post
    On Jason's engine, yes. On mine, I have a euro S50B30 pump/pan/pickups, but it's the same thing.
    Mike
  4. #29
    Apr 2006
    Minnesota eh?
    86 325es
    Quote Originally Posted by MikeE36 View Post
    Mike
    I datalog oil pressure and don't get any dips, but I do have the pan baffled specifically for acceleration. The oil pump pickup is right at the back of the sump and I have a baffle welded across the sump to catch the oil from sloshing out of the sump. I also have a decent size kickout in the sump that is baffled off to provide a steady supply of oil into the sump.
  5. #30
    May 2015
    New York
    2004 M3
    Question on the fender/ wheel setup, Those are the felony form 45mm fenders? What size tire you running out back setup looks perfect.
  6. #31
    Jan 2014
    houston
    2005 g35
    Quote Originally Posted by Dotworks01 View Post
    265/35/18 on a 18x9.5 -2 if I recall correctly
  7. #32
    Austin, TX
    S13, Turbo M3
  8. #33
    Austin, TX
    S13, Turbo M3
    61741192_2492853994275481_5570096412772794368_n.jpg61751184_472254850191983_920638291575832576_n.jpg61229758_674566306321216_7423199089589747712_n.jpg61858692_371817693462630_1443117111764320256_n.jpg
    Mike
    Wideband isn't reading correctly, so I will need to calibrate that, then get it all the way up to temp to heat cycle it, retorque the studs, and then go lean on it!
    Mike
  9. #34
    Oct 2005
    Northern California
    95 M3, 15 Golf TDI wagon
    Looks great!
    I thought these manifolds didn't need an oil siphon pump?
    -WTB: OEM Class 2 LTW GT wing with risers- Mazak
  10. #35
    Sep 2017
    Netherlands
    e36 328i turbo
    Very nice, that steedspeed V2 makes me jealous.
  11. #36
    Austin, TX
    S13, Turbo M3
    Quote Originally Posted by 3literheater View Post
    Looks great!
    I don't think they do, but he had issues with his last manifold setup, so he just wanted to be 100% sure there weren't any drainage issues here.
    Mike
  12. #37
    Mar 2013
    Upstate NY
    M3
    Clean setup, should prove reliably.
  13. #38
    Vancouver, B.C., Canada
    '97 M3
    I left my scavenge pump set up installed just in case as the EFR9180 drain is kinda low.
  14. #39
    Jun 2005
    New England
    F90 M5; E36 M3 Turbo
    Does the subject car’s EFR 7670 sit higher than the 9180 or are both the same frame turbo? I don’t use a scavenge with my 9180 and have not experienced any smoking. I would prefer more slope in the drain to the pan but it seems to work.
  15. #40
    '97 M3
    I run my oil level higher for track use and with higher cornering forces I was concerned about getting smoke on long left handers. It was also easier for me to leave the scavenge pump installed than remove it. Maybe once all the other little issues are dealt with I can experiment with removing the scavenge pump.
  16. #41
    Austin, TX
    S13, Turbo M3
    It is also listed as a "B2 frame" so I would expect very similar placement. It would probably work without the pump, but he is just being extra cautious.
    Quote Originally Posted by chikinhed View Post
    This car will have a lot of oil slosh as well, so it's probably a good precautionary measure.
    Fixed a small leak at the tensioner - forgot a crush washer there, and tightened 1 AN line for the scavenge pump. Need to calibrate the wideband / possibly replace the sensor, and then I should be able to go drive it. 1 bar springs in the wastegates right now.
    Mike
  17. #42
    Austin, TX
    S13, Turbo M3
    Took the maiden voyage today, got it up to temp so I can retorque the head studs tomorrow. It sounds awesome and spools like lightning!
    Mike
  18. #43
    May 2003
    Tampa, FL
    E92 M3, 970TT
    This is very awesome, can’t wait to (hopefully) see some vids.
    991 | 964 | G55 | D90 | LX570 |
    Past: SC'd e34 540/6, CSL'd E46 M3, E36 M3/4/5, E36 M3 turbo, E36 M3, 335D, Porsche 951, 80 Series LC, Kleeman E55 Wagon, LX470, 970 Panamera TT, E92 M3
  19. #44
    Oct 2005
    Northern California
    What syphon pump are you guys using? Just got my 9274...
  20. #45
    Austin, TX
    S13, Turbo M3
    Quote Originally Posted by E34nication View Post
    Thanks! I will absolutely be taking some videos next drive.
    It's a Turbowerx unit. I'm not sure of the exact model.
    Mike
  21. #46
    Austin, TX
    S13, Turbo M3
    It spools like lightning. Need to play with the EBC to get it to hold boost up top as it falls off pretty hard being a tiny turbo on a 3.2L. It's going to make for such an easy and torquey powerband to drive/drift.
    Mike
  1. Replies: 23
    Last Post: 06-08-2005, 06:42 PM
  2. Fs: 95 M3 3.2l Obd1
    By MotorcityM3 in forum BMW Cars For Sale / Wanted
    Last Post: 08-14-2004, 03:57 AM
  3. Update on my 95 M3 3.2L conversion
    By M3Jokster in forum 1992 - 1999 M3 (E36)
    Last Post: 11-06-2003, 09:39 PM
  4. Feeler: my '95 m3 3.2L many many mods...
    By vtrac in forum BMW Parts For Sale
    Last Post: 12-05-2002, 08:43 PM
  5. 95 M3 3.2l vs 96 C4 Vette with Mods
    By MMTuning in forum Kill Stories
    Last Post: 05-31-2002, 10:13 AM
