Results 1 to 21 of 21
Thread: E36 first time turbo build
    May 2018
    Rhode Island
    1994 325i turbo
    1994 bmw 325i
    Engine 1994 m50
    Block
    M52 polished crank
    new race bearings all around
    eagle rods
    CP low comp pistons
    cutring gasket
    arp mains
    arp head
    head
    received full valve job with new guides and seals
    springs and everything checked out ok
    m52 cams
    turbo set up
    new 62/66 ball bearing
    spa t3 manifold
    3inch stainless down pipe and exhaust
    vems stand alone
    1100 cc injectors
    fuel system is stock with
    480lph pump
    And flex fuel sensor
    6speed trans
    grip force flywheel
    m5 clutch
    solid bushings and reinforcements all the way around
    97 m3 rear subframe and diff
    stoptech big brakes in front
    m3 brakes in rear
    ground control suspension with camber plates
    Leaving some things out but that’s most of it so far. At this point I have the engine and trans in and next is timing the motor. This is my first time with this and really want to make sure I get it right. I’ll have some questions and appreciate any help and feed back! I got some photos to upload and some questions for you guys. ����
    Last edited by SaltySam; 05-27-2019 at 09:19 PM. Reason: No need for personal rants
    May 2018
    Rhode Island
    1994 325i turbo
    Does anyone have any experience with the cams lock tools not wanting to lock together well? They both sit flush on the head with cams at tdc. The problem is the little hook at the top doesnít really want to grab the other side. ? I also cheaped out and bought a eBay timing kit ...
    Jun 2005
    Concord, NH
    08 E90M3; 99 E36M3 Turbo
    Is the valve cover stud removed?
    May 2018
    Rhode Island
    1994 325i turbo
    Yes all studs removed. I took a picture but not seeing where I can upload them to thread.
    Virginia
    97' m52 turbo
    Quote Originally Posted by SaltySam View Post
    Does anyone have any experience with the cams lock tools not wanting to lock together well? They both sit flush on the head with cams at tdc. The problem is the little hook at the top doesn’t really want to grab the other side. ? I also cheaped out and bought a eBay timing kit ...
    eBay blocks are garbage. I had the same problem awhile back. Had to borrow a set from a local member
    May 2018
    Rhode Island
    1994 325i turbo
    Thanks for the reply and your right Illjust start with some quality tools because thatís most likely my issue.
    Iím also scared after reading through a pelican article that my oil pressure relief valve was still installed. I never checked and head is already on with cut ring, manifold ect. Is there a way to check this without removing head?
    May 2018
    Rhode Island
    1994 325i turbo
    Couple pics
    Virginia
    97' m52 turbo
    Those block appear to be sitting better than the cheap blocks I was using
    Jun 2005
    Concord, NH
    Thanks for the reply and your right Illjust start with some quality tools because that’s most likely my issue.
    I’m also scared after reading through a pelican article that my oil pressure relief valve was still installed. I never checked and head is already on with cut ring, manifold ect. Is there a way to check this without removing head?
    The machine shop has always either left it or put it back. Hopefully that is the case for you.
    May 2018
    Rhode Island
    1994 325i turbo
    First time using them and After messing around with them for a bit I got it to latch but they did take a little work. I wouldn’t recommend them to anyone. The cams do appear to be timed correctly tho.
    May 2018
    Rhode Island
    1994 325i turbo
    Their a good machine shop and gave me a bag of anything removed already. Ill hope for the best then ����
    While waitng on new vanos studs I began to mock up my piping. Its not tightened down yet and needs some new clamps. The coupler off the 90 on the turbo is really close to the block and manifold. I clocked the turbo best I could was thinking about heat wrapping it with something?
    Jun 2005
    Concord, NH
    You will cook the coupler if it is too close. Wrapping it with fiberglass wrap could help.
    Nov 2015
    Lake Tapps, WA
    99 Turbo M3
    Quote Originally Posted by 328iFun View Post
    I used ebay blocks align the cams install one block then swing arm to fit other side adjust cam according. tighten. then recheck cams after arm has been connected between blocks. timing is perfect. 44$
    99 Turbo M3 - BWs366 - RSI - Fuse Fabrication - JE Cutring -
    May 2018
    Rhode Island
    1994 325i turbo
    Small progress
    I went to install the vanos and related parts today but was sent the wrong bolts. I ordered all new hardware from pelican parts but didnít receive what I needed. Not a big deal just have to wait. In the mean time I set the timing on gears with new chain. Then placed everything where it needs to go. Hopefully this weekend will torque it all and be good to go.
    Next step is to figure out my wiring harness. When I took the car apart I didnít label anything like a dummy.
    Jan 2017
    RI
    1994 325is
    I too have Ebay ( or Amazon ?) blocks. My took a bit of filing to get them to sit right. I got them sitting right before I removed anything, when I knew the cams were locked tdc (flywheel lock pin in, and chain and everything installed). They work fine now though.
    Sent from my SM-G960U using Tapatalk
    Sep 2017
    Netherlands
    e36 328i turbo
    I had the same problem on my setup, coupler was pretty close to the manifold. I used aluminized fiberglass heat insulation. I have about 1.2k (so not that much) now with the new setup and no problems yet.
    May 2018
    Rhode Island
    1994 325i turbo
    Glad to hear itís holding up. I figured a lot of guys run the SPA manifold and would have delt with this. I went ahead and took your idea , thanks
    Nov 2013
    VA
    trbo 96 328;98 m3
    I'm running a reinforced silicone coupler with heat wrap similar to below. After five years of boosting, so far so good.
    https://www.hps-siliconehoses.com/hp...caAh_NEALw_wcB
    96 328 Turbo - 485whp/428wtq
    98 M3/4/5 - Current Project
    May 2018
    Rhode Island
    1994 325i turbo
    best way to check wiring harness
    I didn’t label anything when I took my motor apart and this is a new motor.This weekend I started to wire up my harness. Most of the wires seemed to lay and go where they wanted to. I’ve never done this before but was wondering the best way to make sure I got it right? I was thinking about getting a pin out out from the main harness plug and testing each sensor plug for continuity? So then I just need to order a new crank sensor and do my fuel lines and the manifold can go on.
    Quote Originally Posted by bmw328m52 View Post
    Thanks that seems like the better route to take. I will order one like that
    Jun 2005
    Concord, NH
    May 2018
    Rhode Island
    1994 325i turbo
    Where are you posting parts for sale?
    It seems like the FS section is not used that often anymore. Whatís the most common way you guys are posting parts for sale? Donít tell me everything is on Facebook now lol!
  1. E36 FS e36 m3 big turbo build
    By EuroHB in forum 3 series & Z Series
    Last Post: 01-28-2019, 07:09 PM
  2. first time turbo build newb questions
    By zmillz in forum Forced Induction
    Last Post: 06-01-2016, 02:21 PM
  3. First E36 M... Time to build
    By bklyndubbin in forum BMW Rides & Events
    Last Post: 02-16-2012, 08:48 AM
  4. First E36 M... Time to build
    Last Post: 02-14-2012, 12:34 AM
  5. Need Help planning my first e36 325is(OBD1) turbo build
    By smashed99cbr in forum Forced Induction
    Last Post: 11-28-2007, 01:04 AM
